Hi guys,
I got my sample yesterday and have it soldered now. I have 3v3, GND connect to a 3.3v power supply and RX/TX connected to the USB to Serial adapter. Unfortunately it keeps crashing:
ets Jul 5 2015,rst cause:1, boot mode:(13)
_stack_sentry: 0x3fffe1d0, __stack: 0x40000000,
_bss_start: 0x3fffcd48, _bss_end: 0x3fffe1d0,
_data_start: 0x3fffc000, _data_end: 0x3fffc864
Any pointers what I could do or check?
ESP32 doesn't boot up
Re: ESP32 doesn't boot up
Hi, I'm also having the same problems as you:
*▒́Jul 5 2015,rst cause:1, boot mode:(s
ets Jul 5 2015,rst cause:1, boot mode:(▒
ets Jul 5 2015,rst cause:1, boot mode:(31)
_stack_sent▒
ets Jul 5 2015,rst cause:1, boot mo▒
ets Jul 5 2015,rst cause:1, boot mode▒
ets Jul 5 2015,rst cause:1, boot ▒
It keeps restartnig :/
_stack_sent▒
hi
perhabs try this:
boot firmware on the modul in SPI ( Flash ) Mode:
GPIO 0 pullup ( and high )
GPIO 2 pullup ( and high btw not need - here in test by me ok )
GPIO 5 pullup ( and high )
U0TXD pullup and high level
boot in flash mode ( uploading mode ):
GPIO 0 pulldown ( Low Level )
GPIO 2 pulldown ( Low Level )
perhabs you have a nice future too![Wink ;)](./images/smilies/icon_e_wink.gif)
be sure you have over 20 °C ambient temperature.
i am not sure,but perhabs the boot is temperature "protected"
i search at time this -
perhabs this can help too:
put a pusher between GND and Chip EN, and connect the Chip EN with pullup ( 10 KOhm). you can then "push off/on" ( last picture )
http://esp32.com/viewtopic.php?f=2&t=22&p=253#p240
if you have connect all ( CHIP EN pullup ), do not wait for the boot, you must then shortly push CIP EN down and then high, then the boot process comes.
If you power on, CHip EN not pullup at the time, then the bootprocess comes,
if you connect CHIP EN to high ( pullup ).
if you let open the CHIP EN pin by "air wire" then the wire is "kapazitiv", if you touch the wire, then the SoC try to boot..in undless (loop) - so be sure, Chip EN connect pullup or pulldown. you must terminate the pin.
btw
if you flash the modul, be sure GPIO02 is pulldown, if pullup, flash tool ( windows ) do not upload (can not connect/sync ).
hope this helps.
rudi![Wink ;-)](./images/smilies/icon_e_wink.gif)
perhabs try this:
![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
btw
hope this helps.
rudi
Hi,rudi ;-) wrote:hi
perhabs try this:
i am not sure,but perhabs the boot is temperature "protected"![]()
i search at time this -![]()
btw
hope this helps.
rudi
When I pulled up io0, io2, io5 and EN, this constantly appears on serial port:
ets Jul 5 2015,rst cause:9, bootmode:(3b)
[Here are _stack_sentry and others addresses]
What that could mean?
EDIT: where is U0TXD? when i apply pullup on txd0, i have nothing on my screen
Hiadamj57 wrote: Hi,
yes if you pulled up GPIO 2 then (3b) comes as bootmode.
if you pulled down GPIO 2 then comes (33).
hey! we have RMII ( ethernet ) and other... not sure, but i think we have more more bootables ( SDIO, SDO..) possibles?!
claude already posted the theme RMII
here: http://www.esp32.com/viewtopic.php?f=2&t=56
U0txd is the Uart 0 transeiver pin from ESP.
EDIT: i saw just in time, sry trans"eiver" is the wrong english - i mean the trans"mitter"
but think you have check it for what this stands.
rudi
[1] Rev 1.5 KSD8863 http://www.farnell.com/datasheets/1913744.pdf
Users browsing this forum: Google [Bot], klaatu2, ZapStan_lauby and 121 guests
