Hi,there,
My platform is like this: MCU + ESP32-Wrover works as the server, and a usb dongle as the client. I'm using at command to control and communicate with the ESP32. Using the BTool, I can write to the ESP32 and also get the notification from the esp32. However, after I modified the MTU successfully , I can write to ESP32 more than 20 bytes, well the esp32 still cannot sent the notification more than 20 bytes. According to the debug info, I saw that the mcu has already send the AT+BLEGATTSNTFY successfully with the data (more than 20 bytes), but the usb dongle didnot get any data. If I send the AT+BLEGATTSNTFY with the data equal or less than 20 bytes, it works fine.
So, how can I send more than 20 bytes in one pdu via AT+BLEGATTSNTFY command?
Thx a lot.
Can the AT+BLEGATTSNTFY of esp32-wrover exceed the 20 bytes limitation?
Re: Can the AT+BLEGATTSNTFY of esp32-wrover exceed the 20 bytes limitation?
Sorry for late reply. I dont know AT commands API, but if you have command that allows you to set MTU then you should be able to send notifications mtu-3 length, at least this is ble specs and works with normal code (non AT).
Users browsing this forum: No registered users and 47 guests
