using SSC commands
using SSC commands
Postby rudi ;-) » Thu Dec 17, 2015 11:09 pm
hi
how we can use this SSC commands for test?
tested in terminal
ram
what end character is need?
\n
\r
\r\n
maybe I'm just on the tube..
need a thinking support :)
ESP_Faye
Re: using SSC commands
Postby ESP_Faye » Tue Dec 22, 2015 5:52 am
Hi rudi,
Could you use SSC commands now ?
SSC commands end with "\r\n".
Thanks for your interest in ESP32 !
Postby rudi ;-) » Tue Dec 22, 2015 10:46 pm
ESP_Faye wrote:Hi rudi,
Hi Faye
thank you for thinking at this and demand,
since RTOS SDK 1.1.0 i can play with it, RTOS SDK 1.0.0 do not have the example :oops:
ok, here my result :
btw the bin example in RTOS 1.1.0 is compiled with RTOS 1.0.0.
after boot the screen is "empty" ( no prompt ) :
EDIT2 we have a prompt, see picture at end
ht20 , 2412\r\n
bcn 100\r\n
ok. btw perhabs missed the prompt at start?
ok..now i put ssc command "ram" and send like you suggest with \r\n
USER INPUT : ram\r\n
SOC OUTPUT:
ram\r\n
free heap size:0x12024 73764\r\n
\r\n
looks good,
next user command: i test the same after the response comes,
please, have a look, there is a little \r\n mistake
REMIND SCREEN STAND: :>
USER INPUT again: ram\r\n
SCREEN OUTPUT NOW:
ram\r\n
\r\n
\r\n
:>what?\r\n
so i test after command ram only \r as Send on Enter
and the output looks better:
USER IPUT : ram\r
SOC OUTPUT NOW:
ram\r\n
\r\n
\r\n
i test then only send \r
then the prompt comes always fine.
SCREEN NOW: :>
USER INPUT : \r
SOC OUTPUT:
:>\r\n
(moretime again user \r)
:>\r\n
:>\r\n
:>\r\n
:>\r\n
:>\r\n
test then allways with \r
reboot .. ok
mac -Q o 1
response
mac -Q o 1
mac -Q o 2
response
mac -Q o 2
EDIT1: btw, be noted, there is no MAC response?
btw we have an IP for AP (192.168.4.1)
see ip check
ap -Q -o 3
response
( note have not set client at this time, so think response is ok )
ip -Q o 3\r\n
\r\n
ap ip :192.168.4.1\r\n
Faye, because i have not use op -Q s
think the response at this time with:
op -Q
is ok:
op -Q\r\n
\r\n
get opt\r\n
c 63please check -o param first.\r\n
\r\n
before i try op -S -o ..
can i clear to primordial state by using blank.bin later again ?
is it possible to expand the example by append user code?
or better, have you the or an example in source and can you give free
or an example with one ssc command as example code?
next steps:
client mode, scan, ap mode, check connection ..
thank you for your helpfulness.
Postby rudi ;-) » Tue Dec 22, 2015 11:45 pm
Hi Faye,
just in time i try
op -S -o 1
response:
op -S -o 1\r\n
\r\n
get opt\r\n
c 83 please check -o param first.\r\n
\r\n
have try to set the Station by
op -S -o 1
c 83 please check -o param first..
sta -S -s myhomeAP00 -p examplepass
sta -S -s myhomeAP00 -p examplepass\r\n
\r\n
get opt\r\n
get opt\r\n
get opt\r\n
\r\n
sta -S -s "myhomeAP00" -p "examplepass"
sta -S -s "myhomeAP00" -p "examplepass"\r\n
\r\n
get opt\r\n
get opt\r\n
get opt\r\n
\r\n
btw: 2.2.2 example sta
sta -C [-s ssid] [-p password]
the option -C is missing in table 2.7 sta command parameter
Q: how i can set the client mode to connect to a homeap,
i used the steps
set WiFi as STA mode
connect as client to the ssid pwd
i have just in time in this steps no lucky.
will still try other operations and exchange steps in this.
[no hurry Faye]
thanks!
Postby rudi ;-) » Tue Dec 22, 2015 11:53 pm
Hi Faye,
push
i know, the right command is listed with
.. -Q -o
but if we use
ip -Q o 1
or
ip -Q -o 1
is the same result,
and it response the "AP" IP
btw.
Users browsing this forum: Bing [Bot], Google [Bot], klaatu2 and 141 guests
