rst:0x1 (POWERON_RESET),boot:0x26 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_FEO_V2))
waiting for download
When I execute "make monitor" I get this:$ make flash monitor
Flashing binaries to serial port COM7 (app at offset 0x10000)...
esptool.py v2.3.1
Connecting........_____....._____....._____....._____....._____....._____....._____....._____....._____....._____
A fatal error occurred: Failed to connect to ESP32: Invalid head of packet ('w')
make: *** [/c/esp-idf-release-v3.0/components/esptool_py/Makefile.projbuild:55: flash] Error 2
Which is coming from the local program, not the target. No combination of button pushing/holding provokes the target into any output.--- idf_monitor on COM7 115200 ---
Our board is intended to be as identical to the WROOM as possible. (I hope this is an answer.)kolban wrote:If I were in your shoes, what I'd do now is attach a logic probe to the TX and RX lines of the ESP32 and see what (if anything) is flowing. If nothing, then we have an even bigger mystery. I suspect that you will see data ... we then need to follow that data to see where it goes and where it is being lost. What is the schematic of the RX/TX from the ESP32?
Yes.Are you using a UART->USB module/component?
Not at all...in fact, I'd bet they're not. I'll take your suggestion to the HW guy and have him take a closer look. Thanks...How confident are you that the TX signals coming out of the physical ESP32 are making their way to your PC?
Users browsing this forum: No registered users and 103 guests
