Need help regarding UART1 and UART2 communication for ESP32
Re: Need help regarding UART1 and UART2 communication for ESP32
Sorry. We just checked UART2 in polling based mechanism to verify our hardware which is attached on UART2.
We haven't implemented ISR based or callback based code for UART2 communication interface.
Also, we have compiled ESP-idf RTOS in Linux as well as in Windows Environment..
I will let you know after implementing ISR code.
Regards,
Ritesh Prajapati
Ritesh Prajapati
We have verified both UART1 and UART2 by taking reference of Arduino UART interface code and it works fine without any issue.
So, it seems we can transmit and received data over both UART.
Thanks again for your valuable support to achieve this.
Regards,
Ritesh Prajapati
Ritesh Prajapati
Ritesh wrote:Hi,
How you use Rx Int ?
Do you use handshake too and how you use it in the isr, second or same by mask?
That part of ISR is still remaining. We just verified both UART1 and UART2 interfaces using pooling mechanism as a part of our ESP32 board bringup.
I will let you know after implementing ISR based service routine for both UART.
Regards,
Ritesh Prajapati
Ritesh Prajapati
thanks.Ritesh wrote:Hi,
because serial itself is interrupt driven, ( arduino )
it is unwise to assign a seperate interrupt to it. ( normal )
so i asked - can we we do by own INT pins or must we use the serial interrupt driven or can it be crossed or disabled.. and so on .
so i thinked you are better just checking for serial at various times in your code. ( not sure because i am code outside arduino ide )
thank you!
rudi
That I need to check how Interrupt pin can be used for serial console. Let me check and will let you know later.
Also, we have just integrated Arduino code but we are using ESP-idf RTOS SDK for our ESP32 development stuffs.
Please let me know your exact requirements regarding ISR UART interrupt mechanism so that I can check into code as well.
Regards,
Ritesh Prajapati
Ritesh Prajapati
thanksRitesh wrote:Hi,
i use esp-idf RTOS sdk too, eclipse c code.
ISR on received char ( Rx )
handshake can be done by usually gpio isr
rudi
hi Me-no-dev,ESP_Me-no-dev wrote:Ritesh, you can look into HardwareSerial.cpp as well and see what happens when you start arduino Serial it's pretty straight forward.
ok - UART runs in IDF environment
btw:
void checkForData()
or do we must create a task for lookup?
txs!
rudi
( FYI )
on 115200 -is ur uart bitbang?- there is the first byte 0xFF then comes data
on 9600 the data are fine, but i will check all again
have see the uart driver now in IDF - and WiFive gave me tip for find the watchdog docu fpr CPU 0 .. and other.
think we can now use the driver/uart in IDF too and there is ISR func described. will try this now too.
thank you for you work on this! the things work good.
rudi
rudi
I think UART driver is released into ESP32-idf stack. So, does anyone has verified that code with UART0, UART1 and UART2 interfaces?
Please provide me sample code to verify that code in polling as well as in ISR mode.
Regards,
Ritesh Prajapati
Ritesh Prajapati
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 75 guests
