Hi all does anybody knows how to config visual GDB to build the ESP-ADF project?
is that mean i need to redownload the esp-idf again from github?
what is the ESP-IDF checkout means in Visual GDB ?
- 2018-04-28_105840.png (95.82 KiB) Viewed 4333 times
Re: what is the ESP-IDF checkout means in Visual GDB ?
From ADF README.md (emphasis is mine):
ESP-ADF is based on the application layer of ESP-IDF (Espressif IoT Development Framework). So you need to first install the ESP-IDF and then use the ESP-ADF. Please take a look at Get Started
hi , i have install the ESP_IDF .
does it mean the ESP-IDF checkout need to chose the path of ESP-IDF installed location while i want to develop the ESP-ADF?
Users browsing this forum: No registered users and 99 guests
