[answered] how to get my IP address?
mzimmers
Postby mzimmers » Tue Apr 24, 2018 11:13 pm
I know this is an absurdly simple question, but...I don't know how to determine the IP address I've been assigned by the DHCP server. I've seen some examples of how to do this in linux, but they aren't very portable. Does anyone have a simple technique for this?
Thanks.
Re: how to get my IP address?
Postby ESP_Sprite » Wed Apr 25, 2018 3:17 am
It's given to you in an event. See esp-idf/examples/wifi/simple_wifi/main/simple_wifi.c around line 50 for an example.
mzimmers
Postby mzimmers » Wed Apr 25, 2018 3:44 pm
Ah, thank you Sprite. So is that the only way to get it, or can I retrieve it programmatically (for example, with a LWIP equivalent of ioctl/SIOCGIFADDR?
kolban
Postby kolban » Wed Apr 25, 2018 3:59 pm
Howdy,
The function called "tcpip_adapter_get_ip_info" can be used to obtain your interface IP address, netmask and gateway. You can pass in TCPIP_ADAPTERE_IF_STA to get the information you desire.
fly135
Postby fly135 » Wed Apr 25, 2018 4:27 pm
This is provided in the event handler....
        case SYSTEM_EVENT_STA_GOT_IP:
          eprintf(eLOG_EVENTQ,"SYSTEM_EVENT_STA_GOT_IP\r\n");
          eprintf(eLOG_EVENTQ,"Got IP: %s\r\n",
                   ip4addr_ntoa(&event->event_info.got_ip.ip_info.ip));
mzimmers
Postby mzimmers » Wed Apr 25, 2018 9:30 pm
Hi Neil - yep, that did the trick. Code posted here for anyone else who might be interested (or for me since I'll probably forget).
#include <tcpip_adapter.h>
tcpip_adapter_ip_info_t ipInfo;
char str[256];
// IP address.
tcpip_adapter_get_ip_info(TCPIP_ADAPTER_IF_STA, &ipInfo);
sprintf(str, "%x", ipInfo.ip.addr);
burkulesomesh43
Postby burkulesomesh43 » Fri Oct 26, 2018 6:25 am
mzimmers wrote:Hi Neil - yep, that did the trick. Code posted here for anyone else who might be interested (or for me since I'll probably forget).
char str[256];
// IP address.
I had printed this ip in str, it showing the value 8600a8c0.
Somesh Burkule
Vader_Mester
Contact:
Postby Vader_Mester » Fri Oct 26, 2018 10:46 am
char str[256];
// IP address.
If you used the same formating "%x", then you get the hex value. Try different formating.
task_t coffeeTask()
	while(atWork){
			coffeeDrink(mug);
		} else {
	vTaskDelete(NULL);
Resch2061
Re: [answered] how to get my IP address?
Postby Resch2061 » Fri Oct 26, 2018 12:48 pm
You can print the IP address as octets as follows (from the top of my head):
printf("My IP: " IPSTR "\n", IP2STR(&ipinfo.ip));
burkulesomesh43
Postby burkulesomesh43 » Fri Oct 26, 2018 2:27 pm
Resch2061 wrote:You can print the IP address as octets as follows (from the top of my head):
thank you. its working
Somesh Burkule
Users browsing this forum: ESPBoards and 158 guests
