ESP32 LyraT Battery circuitry not working
glennhuber
Postby glennhuber » Tue Apr 24, 2018 3:37 pm
Has anyone been successful powering and/or charging a battery connected to the ESP32 LyraT board? I have not! :(
ESP_William
Re: ESP32 LyraT Battery circuitry not working
Postby ESP_William » Fri Apr 27, 2018 2:37 am
I have tried and it worked well,wihch I used is a 2000 mAh,3.7V battery,What battery did you use ?
ESP_krzychb
Contact:
Postby ESP_krzychb » Fri Apr 27, 2018 10:02 am
glennhuber wrote:Has anyone been successful powering and/or charging a battery connected to the ESP32 LyraT board? I have not!
Maybe the problem is due not matching polarity of the battery connector as discussed in https://github.com/espressif/esp-adf/issues/9 ?
ESP_William
Postby ESP_William » Thu May 03, 2018 2:54 am
“ Maybe the problem is due not matching polarity of the battery connector as discussed in https://github.com/espressif/esp-adf/issues/9 ?”
—— Sure,you need to make sure the battery JST connector pins match the pin layout on the board appropriately.
Users browsing this forum: No registered users and 24 guests
