I notice that there are 2 camps for debugging via the serial port.
Those that use ESP_LOG(I/W/E), and those that use printf.
I am in the camp of printf because there is less typing involved to get the job done. But I am open to see if there is something I don't know about with using ESP_LOG(I/W/E).
Is this just a matter of preference, or is there a logical reason to use ESP_LOG(I/W/E) over "I've seen it done so that's why I do it" type mentality.
ESP_LOG(I/W/E) vs printf for debug
- ESP_krzychb
- Contact:
Re: ESP_LOG(I/W/E) vs printf for debug
Hi mikemoy,mikemoy wrote:Is this just a matter of preference, or is there a logical reason to use ESP_LOG(I/W/E) over "I've seen it done so that's why I do it" type mentality.
I think that for most of ad hoc debuging this it is a matter of preference with indication to use printf.
ESP_LOG(I/W/E) are intended to implement "permanent" logging functionality in the code and is also used in the ESP-IDF itself. Then depending on debugging scenario it is possible to globally or locally enable required verbosity levels of information to receive.
There are cases of ad hoc logging where ESP_LOG(I/W/E) is more appropriate, see Logging to Host via JTAG.
For myself, I did not like the fact that through menuconfig I could only select one of the 5 options. They should let you select as many as you like. For instance, I could not select Error and Debug.
I think the notion of logging levels including "encapsulated" logging levels is pretty well the common. For example, in Java land:
https://www.tutorialspoint.com/log4j/lo ... levels.htm
Maps:
ALL < DEBUG < INFO < WARN < ERROR < FATAL < OFF.
Maps:
I like the ESP_LOGx macros because you can enable/disable them at runtime. For example, hook up some appropriate MQTT topics and you've got yourself a run-time selectable debug log.
I write two very interesting stories on medium about "ESP_LOGx vs printf" and "Remote control on logs for enabling/disable logs". I think it's interesting for you to check this out.
ESP_LOGx vs printf
https://medium.com/@markevens36/esp-idf ... e24bd6fe78
https://medium.com/@markevens36/esp-idf ... 24acb28218
ESP_LOGx vs printf
I also figured out that printf can get buggy. I regularly miss text from a printf, partially or even totally while this seems to never happen on the ESP_LOGx ; I suppose this is related to thread behavior, printf most likely isn't thread safe whereas ESP_LOGx looks like to be.
Users browsing this forum: Bing [Bot] and 66 guests
