ESP-IDF libmodbus compatibility
playmean
Postby playmean » Wed Oct 11, 2017 11:27 am
Hello, I tried to add libmodbus as component to ESP-IDF environment, but compilation throws me this errors:
$ make all
CC build/modbus/modbus-tcp.o
C:/msys32/opt/esp/esp-idf/components/modbus/modbus-tcp.c:31:24: fatal error: sys/ioctl.h: No such file or directory
compilation terminated.
make[1]: *** [/opt/esp/esp-idf/make/component_wrapper.mk:243: modbus-tcp.o] Error 1
make: *** [C:/msys32/opt/esp/esp-idf/make/project.mk:421: component-modbus-build] Error 2
How it can be fixed or maybe another esp32-friendly lib is present?
shamsul
Re: ESP-IDF libmodbus compatibility
Postby shamsul » Wed Nov 08, 2017 5:42 pm
Hello Playmean,
Did you have a success with libmodbus? I'm looking for a Modbus library that people have successfully used with esp32.
Please share your experience.
Thanks in advance.
spanky
Postby spanky » Thu Nov 30, 2017 8:08 pm
I'm also interested in this.
I've used libmodbus a bunch in a linux environment, but it needs some non-trivial tweaks to get it to work on the esp32. Unfortunately some of the basic libraries are not yet implemented, so its either a case of heavily modifying libmodbus to workaround these missing components, or implementing the underlying libraries for the architecture.
casmeiron
Postby casmeiron » Mon Mar 05, 2018 6:18 pm
Did anyone get this working? We're also in need of such library for ESP32 ESP-IDF platform.
Thanks!
franzhoepfinger
Postby franzhoepfinger » Sat Aug 17, 2024 6:49 pm
working on it.
seems reasonable effort to port libmodbus to ESP-IDF.
i will publish once running.
Users browsing this forum: ElectricThanhTung and 125 guests
