Hello
i'm trying to connect two ESP32 board on the same wifi network using arduino "wifi.h" library.
With the first ESP32 board there is no problem but i can't connect the second ESP32 board on the same wifi after the first one is connected
it seems like the "WiFi.begin" function can't handle a new connection to the same wifi network when a connection is already established
can you hel me?
Thank you
problem with multiple ESP32 board connected to the same wifi
Re: problem with multiple ESP32 board connected to the same wifi
Connecting multiple devices to the same network works for me. Did you try compiling with debuging enabled? Do you have access to the wifi access point, could you maybe get some debugging info from there?
Users browsing this forum: No registered users and 44 guests
