Flash Tool
bienvenu
Re: Flash Tool
Postby bienvenu » Wed Dec 16, 2015 2:55 pm
Thanks rojer9.
$ ./esptool32.py --port /dev/tty.usbserial-FTH159YK read_mac
Connecting...
  File "./esptool32.py", line 557, in <module>
    esp.connect()
  File "./esptool32.py", line 171, in connect
    raise Exception('Failed to connect')
Exception: Failed to connect
My logic analyser is sitting on the end of the through-hole pin, and the castellation is very visibly connected. I suppose the next step is to put a flying wire on the QFN pad and see what's happening there.
Re: Flash Tool
Postby rudi ;-) » Wed Dec 16, 2015 10:04 pm
rojer9 wrote:.. withthe console output you posted, it looks like you get into bootloader fine...
hi
only a question, my first start up starts in few minits:
have checked soldering and board pins, all ok.
have we a bootloader prompt to see ( identify as bootloader mode ) in terminal or comes blank screen? if bootloader prompt, what / how does it say / looks it?
i will start then:
connect GND,
connect 3.3
connect EN to 3.3
GPIO0 to low ( GND )
GPIO2 to low ( GND )
toogle EN 1-2 time
then bootloader must come, right?
flashing the empty flash ic
with posted esptool
then boot ap demo
connected GND,
connect 3.3,
toggle 1-2 EN to 3.3 ( have we no Rest Pin? )
GPIO0 to high ( 3.3 )
right?
till later, will try it now in few minits.
esptool_ESP32.py missing in RTOS SDK folder tools
Postby rudi ;-) » Wed Dec 16, 2015 11:59 pm
hi
just read in the ESP32 RTOS SDK SUB folder "tools", there is just in time no esptool_ESP32.py
have tested the ESP31.py but get no connect just in time.
options like read_mac chip_id ... no connect.
will connect Logic now.
btw:
this was one output i toogle pin EN:
"esp31" is talking with me ;-)
btw:
have we esp31 boot code list for know about # 13 ?
have we esp31 watchdog cause list for know about # 1?
any tips are welcome, puzzle just in time.
i registered, we can not use the "windows" esp8266 flash tool from espressif?
Re: Flash Tool
Postby rudi ;-) » Thu Dec 17, 2015 12:37 am
hi
btw, need we flash_write "esp_init_data_default.bin" for the demo_app?
btw:
get no connect with the esptool_esp31.py
2015-12-17 01-32-38-481.jpg (101.13 KiB) Viewed 19532 times
tip, proposal?
try to analyz with logic now.
bienvenu
Re: Flash Tool
Postby bienvenu » Thu Dec 17, 2015 2:19 am
It sounds like rudi has the same issue as me - the ESP32 (ESP31B?) acts deaf in flash download mode.
EDIT:
Update - I see continuity between breakout pin 34 and ESP31 pin 37, which is listed in the specifications as U0RXD (page 13, "Figure 2-2. ESP31 (Beta Version) Pin Layout"). Pad 37 seems connected to the QFN package - the fillet looks the same as every other one (very good).
Re: Flash Tool
Postby ESP_Sprite » Thu Dec 17, 2015 3:02 am
FWIW, I get 'boot mode 11' here when I go into flash mode... (which works). I will take a look at my bootstrap pin setup when I have time.
Re: Flash Tool
Postby rudi ;-) » Thu Dec 17, 2015 5:34 am
no hurry,
have test more variants after logic.
first time, the esptool have no response,
after little tests and patching then MAC is response:
bandicam 2015-12-17 04-51-20-125.jpg (271.9 KiB) Viewed 19511 times
after next time, boot mode with demo app was response
bandicam 2015-12-17 05-13-56-365.jpg (363.67 KiB) Viewed 19511 times
will check this evening again, why i can't go in bootmode 11 and upload the files.
sry for big files, perhabs admin can convert to small file.
i upload for see the output in original.
btw:
done!
but i cant upload firmware, why, this must be clear at evening.
bye...
@bienvenue
try to deconnect the TX/RX to the USB if you reconnect the modul
@Jer.. think we have a monday breakout :)
btw if you have a second or a reserve.... perhabs you can add me nexttime to a new list.
will try at evening again. so long.
bienvenu
Re: Flash Tool
Postby bienvenu » Thu Dec 17, 2015 6:01 am
rudi ;-) wrote:first time, the esptool have no response,
@bienvenue
What did you do to get it to work, specifically? (The "little test and patching".)
Baoshi
Re: Flash Tool
Postby Baoshi » Thu Dec 17, 2015 8:44 am
I'm using the esptool32.py uploaded by rojer9 and it works all ok, both under Linux and Windows.
There is no esp_init_data_default.bin found in the SDK but I guess it is not important for the moment.
Re: Flash Tool
Postby rudi ;-) » Thu Dec 17, 2015 12:03 pm
bienvenu wrote: What did you do to get it to work, specifically? (The "little test and patching".)
hi bienvenu, sry for wrote name wrong before,
i "massacred" the modul :lol:
i picked it out from [EDIT right word, EDIT add Picture of ] breadboard,
bobbed in into again, and same again, same again,one time then the app was boot, so i stopped this. Soldering Modul on Breakout was ok,but think the U0TXD makes worse ( see 8digit toogle switch table 1-2, the U0TXD on boot SPI is High Level )then i connect gpio0 to low, deconnect EN from high (3.3) this wire was very sensitive then and allways reset boot, then connect this to the EN ( 3.3) again, then was boot mode (13)
@thanks faye for declare boot log http://esp32.com/viewtopic.php?f=16&p=216#p216
but can't upload a new firmware.
( have record with desktop video, will upload for not listed view, and post the link under document folder in forum then , there are more processes to see.)
after try to update with esptool, same position, power off, power on, there is no app boot or no boot mode. so i bobbed it again. i am sure, the special breadboard is top, but will make a fix PCB for the evening and try again. i suspected the U0TXD, will attempt at evening to solder switch with pullup/pulldown and other. the usb TTL stick do not separate properly if you deconnect the board from power, the pins are Rear supply via the USB ( Rx, Tx ) if you power of the modul. (seeks a path through the USB)
btw:
in ESP32 RTOS SDK 1.0 github is declare blank.bin
blank.bin--------->0xfe000(for 1MB SPI Flash)
and in Getting Started after Table 2.2 under point 7 "upload files" is it declare with
blank.bin--------->0xFC000
read the command well, in the last config the command is flashing -fs 2m
that means, that there is use a 2Mbit flash in example,
we have 1 Mbit flash in ESP318 so 0xfe000 is the right.
read carefull Table 2-4 for blank.bin
btw:
the modul are not stocked in
R5
R6
C14
R3
the schematics declare
R5 ~~~~ NC GPIO32
R6 ~~~~ NC GPIO33
C14 --||-- NC GND
R3 ~~~~ NC VDD33
so i think, have no component lost :D
edit: at evening will do next try.
Users browsing this forum: cdollar and 102 guests
