I have code as below. The below line is always failing with error as shown below.
My code is:
static void initialise_wifi(void)
esp_log_level_set("wifi", ESP_LOG_NONE); // disable wifi driver logging
tcpip_adapter_init();
wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
ESP_ERROR_CHECK( esp_wifi_init(&cfg) );
ESP_ERROR_CHECK( esp_wifi_set_mode(WIFI_MODE_STA) );
ESP_ERROR_CHECK( esp_wifi_start() );
void app_main()
ESP_ERROR_CHECK( esp_event_loop_init(event_handler, NULL) );
wifi_event_group = xEventGroupCreate();
initialise_wifi();
xTaskCreate(&printWiFiIP,"printWiFiIP",2048,NULL,5,NULL);
ESP_ERROR_CHECK( esp_wifi_init(&cfg) ) line is failing
- Error_1.png (181.42 KiB) Viewed 2848 times
Users browsing this forum: benrank, Bing [Bot], Google [Bot] and 69 guests
