External flash memory
Hi, I have some nor flash memory like micron M25P80-VMW6TG, how can I connect them to my esp32?
Re: External flash memory
Hi PeWosT,
You can look up the ESP32 datasheet. We use HSPI to connect external flash. You need to follow the protocol of HSPI.
Dear Sir,
I am interested in using ESP-WROOM-32D. I would like to connect an external SPI Flash.
I have made some research on various forums related to above mentioned topic. I have learnt the following alternatives:
1. Connecting to HSPI interface (as mentioned in this post)
2. Connecting to the same SPI Lines as the internal flash, but using a different gpio as a chip select line and using efuse.
I would like to know if there is any configuration steps required to connect external HSPI Flash, do we need to use efuse.
It would be helpful if espressif can release a step by step guide related to interfacing external flash.
Does Espressif provide higher capacity flash in ESP-WROOM -32D modules
Thanks in advance
Thanks in advance
#2 is if you want to replace internal flash and boot from external flash. #1 is if you want to keep internal flash and add external flash for data. No efuse settings required for using hspi.
Thank you for the reply.WiFive wrote:#2 is if you want to replace internal flash and boot from external flash. #1 is if you want to keep internal flash and add external flash for data. No efuse settings required for using hspi.
Users browsing this forum: No registered users and 54 guests
