Hey guys,
Noob question here, I can't seem to complete a build for any of the esp-idf examples.
I'm using MSYS,
I've cloned the esp-idf repository,
Set the IDF_PATH correctly,
but when I go to a directory of one of the examples and try a 'make all' I get this error:
E:/ESP32/esp-idf/make/project.mk:279: *** multiple target patterns. Stop.
I can't seem to build any of the examples, does anyone know what might be happening?
Having Trouble Building esp-idf Examples
Re: Having Trouble Building esp-idf Examples
Not sure, but it sounds similar to https://github.com/espressif/esp-idf/issues/166 . Maybe you can try the solution mentioned there? Basically setting IDF_PATH to something like IDF_PATH=/c/msys32/esp-idf/ instead of IDF_PATH=c:/msys32/esp-idf/
Thanks for the help that seems to have worked
hello halfshellher0
I have the same question when building the esp32-at project use Eclipse IDE on windows.
The esp32-at project was download from https://github.com/espressif/esp32-at.
The first,I'm using MSYS to build it, no problem.
Next I'm using Eclipse to build it,then I got this problem.
I was config the Eclipse like http://esp-idf.readthedocs.io/en/latest ... setup.html.
I have try the solution from https://github.com/espressif/esp-idf/issues/166, but it can't work.
I'm noob here, Can you get me some sugestion, I need your help, thanks.
Users browsing this forum: No registered users and 65 guests
