Hi all,
My project has an external flash chip for which I've written read, write, and erase functions. I'd now like to lay spiffs on top of that. Unfortunately, it looks like the spiffs library bundled with esp-idf does not expose spiffs.h publicly, so I can't call the underlying functions. I copied spiffs.h into my project, and that gets me further, but then I run into locking issues since the included spiffs library defines a couple locking functions in SPIFFS_LOCK and SPIFFS_UNLOCK.
So my question is: Is there a straightforward method of using this library without the ESP specific stuff? And if not, is there a good way for me to include my own copy of it that won't clash with the namespace of the existing one? I have no need for the ESP specific spiffs stuff.
Thanks,
Jason
Use spiffs library with own SPI flash routines?
Re: Use spiffs library with own SPI flash routines?
Thanks for your response Ian. I have indeed attempted to use the Github library directly, by creating a component for it, but when I try to include "spiffs.h" I get conflicts with the one that comes with esp-idf. That's the reason for the second part of my question regarding a clean way to bring it in myself without conflicting with the built in one.wobblyboots wrote:Check out the library on github: https://github.com/pellepl/spiffs
kind regards
Ian.
Thanks,
Jason
Hi Jason,
I think you can use one feature of ESP-IDF build system, namely that you can override one of ESP-IDF components by creating a component with the same name in your project: http://esp-idf.readthedocs.io/en/latest ... -same-name.
This way, if you create 'spiffs' component in your project, IDF build system will disregard the contents of the bundled "spiffs" component: it will not be added to the list of include paths and will not be built. You can then provide your own implementation inside "spiffs" component of your project.
If you have already done that, and seeing build issues, please post a gist of the build log (with make V=1).
Thanks ESP_igrr. I did already try that and I still got conflicts when including spiffs.h, but I didn't investigate very deeply. I will try that again today and report back.ESP_igrr wrote:
Thanks,
Jason
Thanks ESP_igrr, that did the trick! The problem I saw when I tried this before was just that I needed to add a config header. I didn't look close enough at the errors to see that it was almost working.ESP_igrr wrote:Hi Jason,
For future readers, here is what I did:
1. Create components/spiffs.
2. Clone spiffs from https://github.com/pellepl/spiffs to components/spiffs/spiffs.
3. Create components/spiffs/component.mk:
COMPONENT_SRCDIRS := spiffs/src
COMPONENT_ADD_INCLUDEDIRS := spiffs/src .
5. Edit components/spiffs/spiffs_config.h:
* Remove the params_test.h include.
* Add #include <stdint.h>
* Add the following lines near the top:
#ifndef s64_t
#define s64_t int64_t
#endif
#ifndef u64_t
#define u64_t uint64_t
#endif
#ifndef s32_t
#define s32_t int32_t
#endif
#ifndef u32_t
#define u32_t uint32_t
#endif
#ifndef s16_t
#define s16_t int16_t
#endif
#ifndef u16_t
#define u16_t uint16_t
#endif
#ifndef s8_t
#define s8_t int8_t
#endif
#ifndef u8_t
#define u8_t uint8_t
#endif
Thanks,
Jason
Users browsing this forum: No registered users and 103 guests
