Canceled Project
enitalp
Canceled Project
Postby enitalp » Thu Dec 07, 2017 3:56 pm
So my project go canceled and will not make it to marked. Time to share some goodies.
V1 was, Sparkfun and or Adafruit, Some sparkfun RGB Modiule MFRC522 RFID then and CLRC663b RFID Deb board. And in my hand the first produced V2
V1 vs V2.JPG (867.9 KiB) Viewed 11047 times
V2 (on right) Was using an esp wroom and added an Lp55231 for leds and an Clrc663 vs V3 (on left)No FTTDI it as a cable from outside
V2 vs V3.JPG (769.96 KiB) Viewed 11047 times
Back side of V2
enitalp
Re: Canceled Project
Postby enitalp » Thu Dec 07, 2017 4:06 pm
V3
V3 also integrated the USE_MMA9553 And FTDI was back on board
Proto V3.JPG (56.2 KiB) Viewed 11045 times
Proto V3-2.JPG (811.66 KiB) Viewed 11045 times
enitalp
Postby enitalp » Thu Dec 07, 2017 4:13 pm
V4 replaced the MMA9553 for a KX126 ( to add tap and double tap support)
Plus the board size should have been almost the final one.
FTTDI and power, and charging was in a dock outside the wearable
The board
V4 DSC_0034.JPG (469.88 KiB) Viewed 11043 times
Folding with the battery to gon in the box
V4 DSC_0039.JPG (448.22 KiB) Viewed 11043 times
And the box prototype
V4 DSC_0064.JPG (537.44 KiB) Viewed 11043 times
Postby rudi ;-) » Fri Dec 08, 2017 12:52 am
hi
thanks for share.
what happens?
why goes it canceled and not make it to marked?
please tell more about.
enitalp
Postby enitalp » Fri Dec 08, 2017 10:40 pm
Hi.
For a lot of reason.
The harware what not the main product, just an add on. We are video game maker. upper management feared the price of the hardware in stock if the game doesn't sell.
Postby rudi ;-) » Sat Dec 09, 2017 12:57 am
Hi
thanks.
do you think there are alternatives for the add on and you can give the project a chance?
can you speak about? perhabs we can find out in the community a solution for a try?
are you on twitter?
FYI, you are not allone - some people want know more about the project, it looks from begin to the V4 very detailed and perhabs helps drum up funding? what you mean?
that would be without risk but nevertheless an attempt to bring the work and effort on the market
is the upper management ready to talk for this try?
the work is very detailed and and thoughtful.
and I think you deserve it
good work!
(btw: I would take the blue and the white)
Users browsing this forum: No registered users and 11 guests
