Need help regarding UART1 and UART2 communication for ESP32
Re: Need help regarding UART1 and UART2 communication for ESP32
Postby rudi ;-) » Wed Oct 26, 2016 11:50 am
ESP_Me-no-dev wrote:@rudi I especially committed a change so you can safely include Arduino.h in C files as well
thank you , i use here in the test windows binary from espressif, usually i am on linux - i will test later again.
thanks for your effort again - you did SPI ( ESP8266 ) in briliant work - so i am sure - the mistake is here on my desk.
Postby rudi ;-) » Wed Oct 26, 2016 12:27 pm
feedback: perfect!
Thanks! compile without error! ( win binary )
Ritesh
Contact:
Postby Ritesh » Wed Oct 26, 2016 5:20 pm
Can anyone provide sample code to write any character or string buffer on UART1 and to read data from same UART1?
Also provide me startup UART1 configuration to till how to send and receive data.
It will be helpful for me if anyone can provide me ASAP.
Regards,
Ritesh Prajapati
kolban
Postby kolban » Wed Oct 26, 2016 5:32 pm
The hardware abstraction layer samples and code found as part of the Arduino ESP32 library look like they provide what you need:
https://github.com/espressif/arduino-es ... hal-uart.h
The following APIs seem to be present
  • uartBegin
  • uartEnd
  • uartAvailable
  • uartRead
  • uartPeek
  • uartWrite
  • uartWriteBuf
  • uartFlush
  • uartSetBaudRate
  • uartGetBaudRate
  • uartSetDebug
  • uartGetDebug
Ritesh
Contact:
Postby Ritesh » Wed Oct 26, 2016 5:52 pm
Yes. I have checked UART c file in which all above APIs are defined which you have mentioned in your reply.
I just want sample code sequence if anyone has used that code to write/read data for UART1 into Arduino board which will be helpful for me.
Regards,
Ritesh Prajapati
Postby rudi ;-) » Wed Oct 26, 2016 7:28 pm
Ritesh wrote:Hi,
have you read this?
http://esp32.com/viewtopic.php?f=19&t=328#p1398
Ritesh
Contact:
Postby Ritesh » Wed Oct 26, 2016 7:47 pm
Yes. I checked that thread and it seems like that they are going to turn on serial UART2 using Arduino code and I am working on ESP-idf RTOS SDK.
So, let me check compatible functions and configurations for that and will let you know if need any help.
But, it will be more helpful for me if you can provide exact sample code relevant to EPP-idf RTOS SDK as per functions defined in UART driver file.
Regards,
Ritesh Prajapati
ESP_Me-no-dev
Postby ESP_Me-no-dev » Thu Oct 27, 2016 5:26 am
Ritesh, you can look into HardwareSerial.cpp as well and see what happens when you start arduino Serial :) it's pretty straight forward.
#include "esp32-hal.h"
uart_t* uart1;
bool startUart(uint32_t baudrate, int8_t rxPin, int8_t txPin){
  uart1 = uartBegin(1, baud, SERIAL_8N1, rxPin, txPin, 256, false);
  return uart1 != NULL;
void sendSomeData(){
  const char * message = "Hello UART! ESP32 here :)";
  uartWriteBuf(uart1, (const uint8_t *)message, strlen(message));
void checkForData(){
  int i;
  size_t available = uartAvailable(uart1);
  if(available){
    uint8_t out[available];
    for(i=0; i<available;i++){
      out[i] = uartRead(uart1);
    //out now contains all of the available data
Ritesh
Contact:
Postby Ritesh » Thu Oct 27, 2016 8:29 am
Thanks for code snippet.. I have verified on UART2 and it seems working fine without any issue.
I will also check on UART1 as well and will let you know if any difficulty for that.
Thank you very much again.
Regards,
Ritesh Prajapati
Postby rudi ;-) » Thu Oct 27, 2016 9:59 am
ESP_Me-no-dev wrote:Ritesh, you can look into HardwareSerial.cpp as well and see what happens when you start arduino Serial :) it's pretty straight forward.
uart_t* uart1;
  int i;
  if(available){
Thanks - confirm, compile without errors in windows (7, 10 ) environment ( without VM and win binary )
me-no-dev, can u please give a snippy to make INTR on checkForData? ( Rx ) how you like to do this?
can we create (gpio) ISR too on "(rx) gpio way" and do a callback then? (anyedge?)
or do we this with timer and lookup?
thanks for your brilliant work! (Have misjudged you sry )
best wishes rudi ;-)
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 75 guests
