RTC with 32.768 kHz crystal
loboris
Postby loboris » Mon Feb 13, 2017 8:12 pm
Is there any way to configure RTC to run with 32.768 crystal?
This can be very important, as the current implementation of RTC in deep sleep with internal 150 kHz clock is very inaccurate.
On my board (does it depend on board/module ?) RTC runs approximately 3,2% to fast when in deep sleep.
I've tried a kind of callibration (increasing the sleep time by 3.2%, and then adjusting the system time after wake up) and it is much better, but certainly not enough for running for long periods of time.
As I have 32.768 kHz on board, I would like to use it.
ESP_igrr
Re: RTC with 32.768 kHz crystal
Postby ESP_igrr » Mon Feb 13, 2017 8:28 pm
In the current ESP-IDF, using RTC as clock source isn't supported unfortunately. Expect to see support for this by the end of February.
loboris
Postby loboris » Sun Mar 19, 2017 11:12 pm
ESP_igrr wrote:In the current ESP-IDF, using RTC as clock source isn't supported unfortunately. Expect to see support for this by the end of February.
Any news about RTC as clock source support ?
loboris
Postby loboris » Tue Mar 28, 2017 7:15 am
Is this issue considered so unimportant or is it so complicated to implement the support?
ESP_igrr
Postby ESP_igrr » Tue Mar 28, 2017 8:03 am
This feature is planned, sorry that it's taking longer than expected.
eric24
Postby eric24 » Thu May 04, 2017 7:52 pm
Once the 32KHz issues have been worked out, will the ESP32 also support a 32.768KHz square wave input on a single pin (instead of a crystal on two pins)? The reason I ask is because this would provide the option of using an external temperature-compensated oscillator for better frequency stability that a crystal alone can offer.
don.vukovic
Postby don.vukovic » Mon Aug 07, 2017 12:20 am
Has this issue been resolved ?
Any examples available ?
ESP_igrr
Postby ESP_igrr » Tue Aug 08, 2017 2:50 pm
Yes, you can enable 32k XTAL in menuconfig, under ESP 32 specific settings.
onehorse
Postby onehorse » Wed Aug 09, 2017 2:58 am
Any plans to extend this to the Arduino core? My boards also have a 32.768 kHz crystal and I would like to be able to make us of it in my Arduino sketches.
anteph
Postby anteph » Sat Nov 18, 2017 7:21 pm
Hi!
I'm also looking for RTC support on the Arduino core.
It would be awesome to avoid the need for using an external RTC for timestamping, which is a need for most of all sensor related projects.
Best regards,
Nuno Santos
Users browsing this forum: No registered users and 37 guests
