I try follow github to add ESP32 on mac,but still not show in Arduino IDE (1.6.12) .
Please show me step by step.Thanks!
How to add ESP32 in Arduino for Mac?
- ESP_Me-no-dev
Re: How to add ESP32 in Arduino for Mac?
first open Terminal.app
then:
then open/restart Arduino IDE
then:
mkdir -p ~/Documents/Arduino/hardware/espressif
cd /Documents/Arduino/hardware/espressif
git clone https://github.com/espressif/arduino-esp32.git esp32
cd esp32/tools
python get.py
Thanks for your help!ESP_Me-no-dev wrote:first open Terminal.app
then:then open/restart Arduino IDECode: Select all
mkdir -p ~/Documents/Arduino/hardware/espressif cd /Documents/Arduino/hardware/espressif git clone https://github.com/espressif/arduino-esp32.git esp32 cd esp32/tools python get.py
I do it several times, but IDE still no show ESP32 options.
Any suggestion?
It works for me...can you go into the directories you've created and type 'pwd' ?
Thanks a lot!
Finally it shows up.
It's my mistake to input all the code at once.
Should be run step by step.
Hi All!
I believe line 2 with the cd should be relative to the home directory.
Cheers!
cd ~/Documents/Arduino/hardware/espressif
cd esp32/tools
python get.py
Cheers!
Ok, I found it. If you have a different sketch directory in your preferences, the script will obviously not work. So, you need to check where your sketch directory is.
Users browsing this forum: No registered users and 32 guests
