ESP-WROOM-32 specifications
pontificator
Postby pontificator » Mon Oct 30, 2017 10:37 pm
When I compare ESP-WROOM-32 datasheet with ESP-WROOM-02 datasheet, the specs looks almost identical: average current consumption 80 mA, sensitivity -91dBm @ 11 Mbps. But when I test real modules, their performance differs drastically. Running Arduino WiFiScan sketch on ESP-WROOM-32 and on ESP-12F, I can see the following:
- ESP32 module consumes about 120 mA, ESP8266 module consumes less than 70 mA
- ESP32 module can see 5...10 WiFi networks, ESP8266 module can see 14...18 WiFi networks.
It looks like ESP32 module performance is significantly worse than ESP8266. Why?
Regards
sentu19
Re: ESP-WROOM-32 specifications
Postby sentu19 » Tue Oct 31, 2017 3:41 am
pontificator wrote:Hi,
Regards
i having problem with ESP32 after uploading sketch in serial monitor I see ascii character ?? Anyone help pls.
pontificator
Postby pontificator » Tue Oct 31, 2017 10:17 pm
There are several sketches named WiFiScan: for WiFi shield, for ESP8266 and for ESP32. I should upload the sketch for ESP32.
Gfast2
Postby Gfast2 » Fri Nov 03, 2017 1:50 pm
Regards
I've experienced the same issue. This is kind of buggies should be fixed. make sure you use 115200 (stock setting) Baud for serial monitor ("make menuconfig")
GarrettMun
Postby GarrettMun » Sat Nov 04, 2017 9:08 am
Same problem here. I hope it gets fixed asap.
pontificator
Postby pontificator » Sun Jan 14, 2018 10:35 pm
Reapeating the same question:
Why ESP-32 consumes 120 mA average? It should consume 80 mA as per documentation. I have checked several development boards, all consume more than promised. All ESP-32 are quite warm.
Users browsing this forum: Google [Bot], Yahoo [Bot] and 65 guests
