i have some simple questions about ESP32 programming in Arduino :
My setup :
Windows 7, Arduino IDE with latest ESP32 toolchain installed, NodeMCU-32S board, 80Mhz,921600, COM4
The esp32 has two cores, one can assign a task to either one of the cores.
I would like to do some logic on one core: taking input from a sensor (photocell) connected to GPIO25 through a interrupt and ISR (where i take the time when the interrupt fired and store it in a volatile variable "interruptExecuteTime")
On the second core i would like to do the output part (first on serial monitor, later on I2C LCD)
so the question is : how to create 2 tasks and according functions for the two seperate cores, and assign them to the correct core?
how to trigger the different tasks each time the sensors fire the interrupt?
is it OK to pass the data by declaring a volatile variable?
I have done this to start with :
#include "arduino.h"
const byte interruptPin = 25;
volatile int interruptCounter = 0;
volatile double interruptExecuteTime = 0;
static int taskCore0 = 0;
static int taskCore1 = 1;
int numberOfInterrupts = 0;
portMUX_TYPE mux = portMUX_INITIALIZER_UNLOCKED;
void core1Task( void * pvParameters ){
Serial.print("An interrupt has occurred. Total: ");
Serial.print(numberOfInterrupts);
Serial.print(" at :");
Serial.print(interruptExecuteTime);
Serial.print(" on Core :");
Serial.println(xPortGetCoreID());
void handleInterrupt(void * pvParameters) {
portENTER_CRITICAL_ISR(&mux);
interruptExecuteTime = millis(); // this is the important part for me
interruptCounter++;
portEXIT_CRITICAL_ISR(&mux);
void setup() {
Serial.begin(115200);
Serial.println("Monitoring interrupts: ");
pinMode(interruptPin, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(interruptPin), handleInterrupt, FALLING);
xTaskCreatePinnedToCore(
handleInterrupt, /* Function to implement the task */
"handleinterrupt", /* Name of the task */
10000, /* Stack size in words */
NULL, /* Task input parameter */
0, /* Priority of the task */
NULL, /* Task handle. */
taskCore0); /* Core where the task should run */
core1Task, /* Function to implement the task */
"core1Task", /* Name of the task */
taskCore1); /* Core where the task should run */
void loop() {
if(interruptCounter>0){ // greater than 0 means there was a interrupt fired
portENTER_CRITICAL(&mux);
interruptCounter--; // decrease to reset the value
portEXIT_CRITICAL(&mux);
numberOfInterrupts++; // count the numbers of interrupts fired at this moment
if (numberOfInterrupts >= 25){
esp_restart(); // restart example by cleaning all data and resetting MCU
C:\Users\Beheerder\Documents\Arduino\ESP32 projects\esp_restart_with_interrupts_example1\esp_restart_with_interrupts_example1.ino: In function 'void setup()':
esp_restart_with_interrupts_example1:34: error: invalid conversion from 'void (*)(void*)' to 'void (*)()' [-fpermissive]
In file included from C:\Users\Beheerder\Documents\Arduino\hardware\espressif\esp32\cores\esp32/esp32-hal.h:52:0,
from C:\Users\Beheerder\Documents\Arduino\hardware\espressif\esp32\cores\esp32/Arduino.h:35,
from C:\Users\BEHEER~1\AppData\Local\Temp\arduino_build_465995\sketch\esp_restart_with_interrupts_example1.ino.cpp:1:
C:\Users\Beheerder\Documents\Arduino\hardware\espressif\esp32\cores\esp32/esp32-hal-gpio.h:81:6: note: initializing argument 2 of 'void attachInterrupt(uint8_t, void (*)(), int)'
void attachInterrupt(uint8_t pin, void (*)(void), int mode);
exit status 1
Since i am a absolute beginner on the ESP32 platform, this looked like a no-brainer, but that came out very different
What am i doing wrong?
What should i read as documentation on this?
Grtz,
Yves
