Problems after updating to latest master (reproduced in IDF example code)
permal
Postby permal » Fri Oct 06, 2017 9:24 pm
So a month spent on designing some hardware, I'm now back to continue working on my software. Since the pthread-support has been added to IDF, I've updated to the latest IDF-master and the latest xtensa-gcc (xtensa-esp32-elf-linux64-1.22.0-73-ge28a011-5.2.0).
The update process itself went fine, but I am now experiencing garbage being printed to the monitor and complete application hangups - no crash dump being printed.
V (436) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): checking args
V (440) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): Args okay. Resulting flags 0xE
D (448) intr_alloc: Connected src 49 to int 17 (cpu 0)
D (1235) event: SYSTEM_EVENT_STA_CONNECTED, ssid:Our place, ssid_len:9, bssid:f0:9f:c2:aa:b0:3f, channel:11, authmode:3
V (1236) event: enter default ca��KV֬��WL�
q Q&&MLJ�Y�Y��: exit default callback
V (1243) Application: ESP32 station`cϹ���ѕ����)գ+L[
I've looked through the commit log for hints on what could cause this, but I've not really found anything except that there seems to have been a few errors regarding the pthread-support. I also had a look at the current issues, but didn't find anything seemingly related.
This code ran fine before recompiling with the new IDF/gcc. It seems to be a threading issue since running only the main thread seems to work fine.
Any help will be welcome, I'm at loss at the moment.
kolban
Re: Problems after updating to latest master
Postby kolban » Sat Oct 07, 2017 5:12 am
In situations like this, I usually try two quick tests:
1. Delete the build directory which causes everything to be rebuilt
2. Replace the SDKCONFIG with a new one from a fresh template and re-make any necessary changes that you originally made
permal
Postby permal » Sat Oct 07, 2017 8:18 am
If it only had been something that simple...its not, however.
permal
Postby permal » Sat Oct 07, 2017 9:07 am
Problems seems to be related to WiFi. I've minimized my app and as soon as I start WiFi, I get this, with a complete hang:
D (1441) tcpip_adapter: dhcp client init ip/mask/gw to all-0
D (1447) tcpip_adapter: if0 start ip lost tmr: enter
D (1452) tcpip_adapter: if0 start ip lost tmr: no need start because netif=0x3ffc����J��+ɱ�a��J���ڴj5R"B����J�����}�W.W�.' dhcp�ƥ��с�х��H�]�cessfully[�jH��&��rJ����}����ѕ��l+�
R�-HZw �ݥ���������B:�ٕ������j5R"B��:��JH���%�}��.W�.'H��eck: remo��� )�V�2����C������Hh�j5R�B����J*ٕ���*��с"����bс���KV�X�F+L[C�� (1h82)
��%��ѥ�����*�&&H.]��i޹������ѕ���=�
Am��j5�
WiFive
Postby WiFive » Sat Oct 07, 2017 9:51 am
Can you reproduce with any idf example code?
permal
Postby permal » Sat Oct 07, 2017 12:21 pm
WiFive wrote:Can you reproduce with any idf example code?
I haven't tried yet. It's too early to point fingers ;)
permal
Postby permal » Sat Oct 07, 2017 12:47 pm
I can actually reproduce it with an IDF-example!
IDF-hash: de750e99214a51c1bcfdb42b5ada931652a3c531
xtensa-gcc: xtensa-esp32-elf-linux64-1.22.0-73-ge28a011-5.2.0.tar.gz
Here is the out from iperf, with verbose logging enabled:
query
query WiFi info
restart
Restart the program
iperf [-sua] [-c <ip>] [-p <port>] [-i <interval>] [-t <time>]
iperf command
-c, --client=<ip> run in client mode, connecting to <host>
-s, --server run in server mode
-u, --udp use UDP rather than TCP
-p, --port=<port> server port to listen on/connect to
-i, --interval=<interval> seconds between periodic bandwidth reports
-t, --time=<time> time in seconds to transmit for (default 10 secs)
-a, --abort abort running iperf
esp32> sta "My SSID" MyPassword
I (14496) iperf: sta connecting to 'Our place'
D (14498) event: SYSTEM_EVENT_STA_START
V (14499) event: enter default callback
D (14510) tcpip_adapter: check: local, if=0 fn=0x40113ab0
0x40113ab0: tcpip_adapter_start_api at /home/permal/esp/esp-idf/components/tcpip_adapter/./tcpip_adapter_lwip.c:935
D (14511) tcpip_adapter: call api in lwip: ret=0x0, give sem
D (14522) tcpip_adapter: check: remote, if=0 fn=0x40113ab0
V (14523) event: exit default callback
D (15301) event: SYSTEM_EVENT_STA_CONNECTED, ssid:Our place, ssid_len:9, bssid:f0:9f:c2:aa:b0:3f, channel:11, authmode:3
V (15303) event: enter default callback
D (15314) tcpip_adapter: check: local, if=0 fn=0x40113d00
0x40113d00: tcpip_adapter_up_api at /home/permal/esp/esp-idf/components/tcpip_adapter/./tcpip_adapter_lwip.c:935
D (15315) tcpip_adapter: call api in lwip: ret=0x0, give sem
D (15326) tcpip_adapter: check: remote, if=0 fn=0x40113d00
D (15327) tcpip_adapter: check: local, if=0 fn=0x401141b4
0x401141b4: tcpip_adapter_dhcpc_start_api at /home/permal/esp/esp-idf/components/tcpip_adapter/./tcpip_adapter_lwip.c:935
D (15338) tcpip_adapter: dhcp client init ip/mask/gw to all-0
D (15338) tcpip_adapter: if0 start ip lost tmr: enter
D (15349) tcpip_adapter: if0 start ip lost tmr: no need start because netif=0x3ffce834 interval=120 ip}ӣ+L3
B(1Z��'�JH�,\Z��+W�.'HY�,\H,[ZY�� start su
permal
Re: Problems after updating to latest master (reproduced in IDF example code)
Postby permal » Sat Oct 07, 2017 4:23 pm
I made a local copy of the iperf example to be able to run the same test in older IDF versions and downgraded IDF as far back as commit b70329040d974507a442a46d424b7ee7dbc563d4 Sep 13, 2017 at which the problem still remains. I can't go further back than that as I don't have access to older versions of the xtensa-gcc tool chain.
jsurfage
Postby jsurfage » Sat Oct 07, 2017 6:07 pm
The other thing I've done is erase the flash and then return the image...
permal
Postby permal » Sun Oct 08, 2017 10:02 am
jsurfage wrote:The other thing I've done is erase the flash and then return the image...
Tried that, didn't help.
Anyone else who has tried the iperf example with the latest xtense-gcc and latest IDF master?
Users browsing this forum: Baidu [Spider] and 89 guests
