I have upgraded the esp-idf to release 2.1 and after that none of the examples are working. the code compiles and i am able to program the device but its not working. it outputs some hex values in the terminal.
i have also updated the esptool to esptool.py v2.1
python version i am using is 2.7
is there anything i am missing ?
run time error after upgrading the esp-idf to release 2.1
Re: run time error after upgrading the esp-idf to release 2.1
Howdy,
Perhaps you can post the output of the console log ... I'm afraid there isn't yet much to go on to provide assistance.
Hi Kolban,
As always you are the first one offer some assit, thank you so much for all the support.
i am attaching the log message here.
also How can i update the extensa-toolchain? would that be the problem.
Howdy,
I'm afraid it doesn't look like the attachment made it ...
here is the log
The hex output will come for around 30 sec and then nothing happens. I am getting the same result for every example codes.
the current version of xtensa tool-chain i am using is : crosstool-NG crosstool-ng-1.22.0-61-gab8375a
i have also tried :crosstool-NG crosstool-ng-1.22.0-73-ge28a011 , with this one, i am getting a warning message as toolchain is not supported.
- Screenshot from 2017-10-06 20-41-33.png (110.42 KiB) Viewed 9036 times
- Screenshot from 2017-10-06 20-40-57.png (85.06 KiB) Viewed 9036 times
thank you.
now its working
now its working
Users browsing this forum: Baidu [Spider] and 43 guests
