Translated with DeepL.com (free version)
chegewara wrote: ↑Tue Feb 11, 2025 4:07 pmHi,
using ble on P4 with hosted should be fairly easy.
When you want to use nimble as the stack it should work out of the box, with no extra code, as far as i remember.
Recently esp_hosted has been updated and you can use bluedroid stack. In this case some extra code is required, just few lines, and some bledroid init code has to be removed, but the whole process is really easy.
Personally i like to use this library as component to work with nimble and esp-idf and it should be updated to work on P4 already:
https://github.com/h2zero/esp-nimble-cpp
You can pick any example and it should works.
# This file was generated using idf.py save-defconfig. It can be edited manually.
# Espressif IoT Development Framework (ESP-IDF) 5.4.0 Project Minimal Configuration
CONFIG_IDF_TARGET="esp32p4"
CONFIG_ESPTOOLPY_FLASHSIZE_16MB=y
CONFIG_PARTITION_TABLE_CUSTOM_FILENAME="partitions.csv"
# Override some defaults so BT stack is enabled
# in this example
# BT config
CONFIG_BT_CONTROLLER_DISABLED=y
CONFIG_BT_BLUEDROID_ENABLED=n
CONFIG_BT_NIMBLE_TRANSPORT_UART=n
# Enable ESP Hosted BT
# Used as VHCI transport between BT Host and Controller
CONFIG_ESP_ENABLE_BT=y
CONFIG_ESP_WIFI_REMOTE_LIBRARY_HOSTED=y
CONFIG_ESP32_P4_EV_BOARD=y
CONFIG_PARTITION_TABLE_CUSTOM=y
CONFIG_COMPILER_CXX_EXCEPTIONS=y
CONFIG_BT_NIMBLE_ENABLED=y
CONFIG_HTTPD_MAX_REQ_HDR_LEN=800
CONFIG_HTTPD_WS_SUPPORT=y
CONFIG_ESP_WIFI_EXTRA_IRAM_OPT=n
CONFIG_ESP_WIFI_SLP_IRAM_OPT=n
CONFIG_FATFS_LFN_HEAP=y
CONFIG_FREERTOS_HZ=1000
CONFIG_ESP_HOSTED_ENABLE_BT_NIMBLE=y
CONFIG_SLAVE_IDF_TARGET_ESP32C6=y
## IDF Component Manager Manifest File
dependencies:
espressif/esp_hosted:
version: "*"
rules:
- if: "target in [esp32p4]"
espressif/esp_wifi_remote:
version: "*"
rules:
## Required IDF version
idf:
version: ">=4.1.0"
NimBLEDevice::init("");
NimBLEDevice::setMTU(517);
pBLEScan = NimBLEDevice::getScan();
pBLEScan->setScanCallbacks(new MyAdvertisedDeviceCallbacks());
pBLEScan->setDuplicateFilter(true);
pBLEScan->setInterval(1000);
pBLEScan->setWindow(500);
pBLEScan->setActiveScan(1);
pBLEScan->clearResults();
Users browsing this forum: Google [Bot] and 102 guests
