I use GPIO interrupt & GP timer to create an algorithm to drive a triac by calculating the phase to produce a firing impulse. This works well.
However the application uses MQTT/WiFi connection to exchange data with an external application. When there is such communication (incoming and outgoing messages) the phase control is disturbed for while, until the communication is ongoing.
How to prevent this? Is it possible to be prevented? May be GP timer is used in Wifi module? Someone experienced such behavior?
Regards, Ivan
GP TIMER and WiFi/MQTT modules?
Re: GP TIMER and WiFi/MQTT modules?
You can run the TRIAC control on Core 1 and Wi-Fi on Core 0:
xTaskCreatePinnedToCore(mqtt_task, "MQTT", 4096, NULL, 1, NULL, 0);
xTaskCreatePinnedToCore(triac_task, "TRIAC", 4096, NULL, 2, NULL, 1);
Users browsing this forum: Corand and 101 guests
