Can I use the 5V power port on the ESP32 to power the sensor?
meloy9
Postby meloy9 » Sat Feb 08, 2025 2:37 am
hello,everyone!
I am using a development board from the ESP32-DevKitC series, and the sensor requires a 5V operating voltage. The pinout for the ESP32-DevKitC board is as follows. Can I use its 5V power rail port to connect the sensor's VCC power supply? Because the ESP32's GPIO port operates at 3.3V, will this cause a conflict and damage my development board?
ahsrabrifat
Re: Can I use the 5V power port on the ESP32 to power the sensor?
Postby ahsrabrifat » Sat Feb 08, 2025 11:43 am
Yes. You can.
mikemoy
Postby mikemoy » Sat Feb 08, 2025 5:30 pm
Yes, but what voltage is your sensors output voltage? If 5v as well you have to bring that down to 3.3v.
hedayR
Postby hedayR » Tue Feb 11, 2025 12:17 pm
The 5V of the board can supply power to the sensor; if the sensor needs 3.3V, then it needs to be connected to the 3.3V power supply; otherwise, the sensor will be burned out.
Users browsing this forum: No registered users and 168 guests
