Irreversible damage to ESP-12F when using GPIO0 as output for P-MOS
rcpilot1604
Postby rcpilot1604 » Wed Jan 15, 2025 3:00 am
Hi everyone I would like to share some findings from some experimentation I did today and also to see if anyone has experienced similar issues.
I am using the ESP-12F castellated ESP8266 modules from a supplier from China to design a relay PCB.
Due to a shortage of GPIO pins I used GPIO0 as an output to a P-MOS and an N-MOS (common gate). I reckoned it would be fine to do so as long as GPIO0 was pulled up and was high on boot. However after assembling a full PCB I found that the ESP-12F chip could not be flashed via Arduino IDE:
A fatal esptool.py error occurred: Failed to connect to ESP8266: Timed out waiting for packet header
I started experimenting with first removing one component at a time until I was left with the necessary components to flash the ESP-12F (pullup/down resistors on GPIO0,2,15, CH340C, UMH3 etc) but still to no avail.
Then I decided to first assemble these minimally required components onto a new PCB, flash the ESP12-F, and then start adding one component at a time, testing the flashing process after each addition.
It turns out that upon adding Q5 (schematic) [FDN340P logic level PMOS whose gate is connected to GPIO0], the ESP-12F is irreversibly damaged (can no longer flash even after removing Q5). Before adding Q5, the voltage across GPIO0 was 3.3V as expected however after adding Q5 (and even after removing it), the voltage could only reach ~2V.
I have linked my EasyEDA schematic and board files here: https://drive.google.com/drive/folders/ ... sp=sharing
Has anyone successfully used GPIO0 on ESP8266 to control a PMOS? Or does anyone have an explanation for why this issue is occurring? I designed my PCB using the WeMos D1 Mini as a reference: https://www.wemos.cc/en/latest/_static/ ... v3.0.0.pdf
Thanks! :D
Users browsing this forum: ESP_Sprite and 6 guests
