Receive multicast packets with AT + CIPSTART
akarg96
Postby akarg96 » Thu Feb 13, 2020 6:20 am
I have a question about UDP multicast.
Execute AT + CIPSTART = "UDP", "192.168.0.2", 0, 12345, 2 and OK will be displayed on the serial monitor. When I send UDP packets with PacketSender, + IPD, 5, hello is displayed.
When AT + CIPSTART = "UDP", "239.192.1.2", 0, 12345, 2 is executed, the serial monitor displays OK, and it is considered that the socket was correctly created. However, the PacketSender does not display + IPD when sending UDP packets to a multicast address.
Does AT firmware not support multicast?
Also, I don't want to use AT + MDNS.
I use google translation.
Thank you.
Helen L
Re: Receive multicast packets with AT + CIPSTART
Postby Helen L » Thu Feb 13, 2020 11:19 am
It seems that ESP32 AT does not support multicast for now, maybe it should be added in the future.
ESP_XCGuang
Postby ESP_XCGuang » Mon Feb 24, 2020 11:00 am
Please try it again using the attachment
esp-at.bin.zip
(861.68 KiB) Downloaded 618 times
akarg96
Postby akarg96 » Tue Feb 25, 2020 12:52 am
Thanks Helen L and xcguang.
I understand that ESP-AT does not support multicast.
Using the given bin file, the AT + CIPSTART command definitely received the multicast.
ESP_XCGuang
Postby ESP_XCGuang » Wed Feb 26, 2020 3:34 am
Hi akarg96,
thanks for your feedback, we will sync at GitHub ASAP, if you have any question about esp-at, you can report it at https://github.com/espressif/esp-at/issues
Bitloose
Postby Bitloose » Tue Jan 14, 2025 3:13 pm
I can't believe that it isn't noted that the ESP-12 and other WiFi modules don't support UDP multicast!!!
After hours of tests and searches I came to the same conclusion.
Hours of work that many developers have suffered because no one at Espressif bothered to update the documents! :roll:
Would you PLEASE publish what the recommended course of action is?
Users browsing this forum: No registered users and 97 guests
