ESP32 C3 Development Board wont print to serial monitor
Re: ESP32 C3 Development Board wont print to serial monitor
I have pressed Boot button when download code. And USB serial started to work fine
If nobody has solved the issue, I figured it out for myself. under the tools tab in arduino IDE, check the upload speed that it is set at by default. I set the device to "ESP32C3 Dev module" when going to "select other board and port.." under the tools tab and the upload speed is default at 921600. after changing my code and baud rate to match, I got serial data printing on my screen!
In Arduion IDE, I choose Nologo ESP32C3 Super Mini and the problem has been fixed.
Users browsing this forum: Bing [Bot] and 97 guests
