@username
Ok. Here is my updated schematic.
I added capacitors, as you said. I guess this is for voltage stability purposes.
Can you confirm my schematic seems correct ?
Problem with custom PCB with ESP32 WROOM E and sketch uploading
Re: Problem with custom PCB with ESP32 WROOM E and sketch uploading
Not that way. For the AMS1117 parallel both caps and place one end of both caps to pin3, and the other to gnd.
Then do the same on pin 2 with the other 2 caps.
For the CH340 pin 16 you have the 4.7uf wired ok, just place the 0.1uf cap parallel with it.
This is the idea.
This is the idea.
@username
I think I understood what you mean. Here is my newly updated schematic. Do you see any failure ?
You got it. If you still have troubles I would try changing out the 4.7uf on the EN RC network to something like a 0.1uf.
@ESP_Sprite and @username
Perfect, thanks a lot to both of you for your support and helpful answers. I will keep you informed about the situation when my new board arrives !
EDIT : The new board arrived and all is working perfectly. Thanks to you guys !
Users browsing this forum: Bing [Bot] and 52 guests
