ESP32-C3 SuperMini connecting to wifi work only when touching antenna
jingo09
Postby jingo09 » Wed Sep 18, 2024 10:23 am
Hi, I bought a new board and I can only connect to wifi when I touch with my finger (some other objects might also work) above or on the side of the antenna or under the antenna (under the pcb). this is only help when i try to connect to wifi but with esp-now delivery is failed.
I tried a separate power supply but still the same. What can cause that issue and dose anyone have a fix for this?
MicroController
Re: ESP32-C3 SuperMini connecting to wifi work only when touching antenna
Postby MicroController » Thu Sep 19, 2024 7:47 am
jingo09
Postby jingo09 » Thu Sep 19, 2024 10:33 am
May be the same issue: https://esp32.com/viewtopic.php?f=2&t=41899#p137764
Thank you, it worked. I needed also WIFI_STA before and 40/10db.
WiFi.mode(WIFI_STA);
esp_wifi_set_max_tx_power(40);
Dose the cause of the problem is the board circuit? I noticed it different than my other ones and it also doesn't look the same as the product page image.
Fusion
Postby Fusion » Thu Sep 19, 2024 4:30 pm
It is related to antenna design. I made a custom board where it was very hard to implement the recommended antenna keep-out clearance and used a similar ceramic antenna. I had to reduce tx power to get it to connect to networks. This is not an issue if the board is always close to the router.
jingo09
Postby jingo09 » Thu Sep 19, 2024 5:31 pm
I see now, the good boards have a lot more clearance and they also have small holes. thanks.
BerndN
Postby BerndN » Tue Nov 26, 2024 9:37 am
I tested the workaround
Then I saw in
http://esp32.io/viewtopic.php?f=19&t=42069
the pin 21 issue.
I soldered out the single row male pin 21 and removed
again and it connected every time. :shock:
DahBenni
Postby DahBenni » Sun Dec 08, 2024 10:44 am
I also had the same issues and wanted to try esp_wifi_set_max_tx_power(40);
But as I had to rewrite too much other code I simply started to unsolder / disconnected an external LED from GPIO Pin 21.
Surprise: It resolved my issues instantly :)
Thx!
Users browsing this forum: lbernstone and 28 guests
