i have come to this situation, while trying to implement the peripheral touch_pad, you have to use int to set it up:
touch_pad_init();
and then in the example there is a loop that reads everything. The problem is that you are not given the option to set what gpio you want to actually use, and apparently sets all available touch_gpio's as touchable?
my question is, what happens if im not using all the gpios as touch, there are 9 touch available but im only using 4, the other are being implemented as input and outputs.
is it an issue? or should i just call the touchpad init before i set the other gpio as outputs?
thanks in advance
touch pad, not using all the available gpio as touch, is it a problem?
Re: touch pad, not using all the available gpio as touch, is it a problem?
Touch pad driver should be initialized before use by calling function touch_pad_init()
Enabling of touch sensor functionality for particular GPIO is done with touch_pad_config().
https://esp-idf.readthedocs.io/en/lates ... h_pad.html
Users browsing this forum: Baidu [Spider] and 127 guests
