A fatal error occurred: Failed to connect to ESP32-C2: Invalid head of packet (0xE3): Possible serial noise or corruption.
Additionally, I have tried using idf.py for flashing as well as Espressif IDE, but I encounter similar issues in both cases, preventing successful code flashing.
System Setup:
Chip Model: ESP8684-WROOM-01C
Development Environment: ESP-IDF v5.2.2
USB-to-Serial Adapter: USB-Enhanced-SERIAL CH9102
Power Supply: 3.3V regulated supply
Troubleshooting Steps Taken:
Verified the connections of TX, RX, 3.3V, GND, GPIO0, and EN pins.
Confirmed GPIO0 is held low during reset to enter bootloader mode.
Tried flashing at multiple baud rates (115200, 74880, etc.).
Tested with a different USB-to-serial adapter and COM port.
Updated esptool.py to the latest version (v4.8.1).
Attempted on an alternate computer to rule out local configuration issues.
Despite these steps, I continue to encounter the "Invalid head of packet" error. I would greatly appreciate any additional guidance or troubleshooting recommendations for resolving this issue.
I am unable to connect to the ESP8684 module for flashing using esptool.py. When attempting to run the flash_id command,
Re: I am unable to connect to the ESP8684 module for flashing using esptool.py. When attempting to run the flash_id comm
Add a small capacitor (typically 10 μF) between the EN pin and GND. This can stabilize the signal and sometimes helps with communication issues during flashing, especially on ESP8684-based setups.
we try this way too. but nothing has changed, we have the same problem
Users browsing this forum: Google [Bot] and 105 guests
