ESP32-P4 CPU frequency 360MHZ
username
Postby username » Wed Oct 30, 2024 11:39 am
Espressif mentions, "Powered by a dual-core RISC-V CPU running up to 400MHz"
https://www.espressif.com/en/news/ESP32-P4
When I create a new project for it using ESP-IDF v5.3.1 the highest setting is 360MHZ.
Actually the only setting is 360Mhz.
Is it just to new to have all the typical freq settings ?
Re: ESP32-P4 CPU frequency 360MHZ
Postby ESP_Sprite » Wed Oct 30, 2024 11:59 pm
Yes. The current ESP32P4s that you can obtain are limited runs (more-or-less engineering samples). After the final mass production is done, we'll fully test the chip to see if it can run at 400MHz in all circumstances and adjust the menuconfig options accordingly.
Users browsing this forum: jjsch-dev and 81 guests
