“""A fatal error occurred: Failed to connect to ESP32: No serial data received.”
quinntapia
Postby quinntapia » Mon Jul 22, 2024 6:22 pm
I am just getting started in microcontrollers and would appreciate you giving me help with the following problem. Your help may need to be detailed and simple. I am to the point where I have downloaded a built-in sketch example. When compiling, the sketch appears to compile but then at the end it states:
“A fatal error occurred: Failed to connect to ESP32: No serial data received.” “Failed uploading: uploading error: exit status 2”
I have a DO IT ESP32 DEVKIT V1 connected to COM Port 1.
Thank you, I am very grateful for your help.
Dennis
thaynos
Re: “""A fatal error occurred: Failed to connect to ESP32: No serial data received.”
Postby thaynos » Sat Oct 26, 2024 10:03 pm
have you found any solution for this?
Users browsing this forum: No registered users and 101 guests
