I have a couple of Expressif esp32 dev boards. I want to add a W5500 lite so I don't rely on wiFi I have a terminal adapter board that I am using currently. What I am looking for is something similar but with the w5500 mounting area with traces to the esp32 pins. Does anyone know where I might get one of these boards, if they are available. I searched around Amazon but found nothing.
Ed
in search of a breakout board
Re: in search of a breakout board
Thanks username for the link, that is the exact W5500 I have. Maybe I didn't share what I want very well. I have a breakout board for the esp32 with terminal strips. I want an integrated board that I can attach the esp32 and the W5500 with tracing for the connections between them. I saw one on a review of the W5500 a board that had them both mounted and it looked sweet. I tied to contact the reviewer and or track down the board but to no avail.
Thanks for any ideas
Oh, OK. Maybe this will suffice ?
https://www.waveshare.com/esp32-s3-eth.htm?sku=28972
Ah Those look interesting. alas I already have a module and the W5500 jack. If I didn't already have what is working I would definately go for the module you suggested. I would have to rewire my setup. Would you know if that ESP32 board would work with ESP home and Home Assistant? I would need a mounting board similar to what I have so I could get the outputs to my terminal strips. I have considered creating a PCB for what I have. Not so easy so far.
- 610pqixuQaL._AC_SX679_.jpg (40.72 KiB) Viewed 1662 times
- PXL_20240903_001955108.MP.jpg (512.32 KiB) Viewed 1662 times
there are modules with ESP32 and Ethernet on board, e.g. the WT32-eth01https://github.com/egnor/wt32-eth01, the ESP32-Ethernet-Kit v1.2 https://docs.espressif.com/projects/esp ... guide.html, etc
Users browsing this forum: No registered users and 30 guests
