Esp32S3 : SD Spi driver with 16Gb SD Card does not work
Good evening,
I have used the SDSpi example with Esp32S3 in order to mount a FileSystem with VFS on a 2Gb micro SD Card (Spi)
using standard SPI mode.
Everything is ok.
Now, I have changed the SDCard with a 16Gb microSD Card and the same example/driver does not
manage to mount the FileSystem.
Do you think this example is compatible with SDHC 16Gb cards ? Do you think I have to change the
standard SPI mode with a quad spi mode ? If the answer is yes, how do do that ?
At the moment I don't understand why the driver does not manage to mount my 16Gb card....
Please help me
Do you have any ideas please ?
Best regards,
Thomas TRUILHE
Everything is ok.
Please help me
Best regards,
Thomas TRUILHE
- Contact:
Re: Esp32S3 : SD Spi driver with 16Gb SD Card does not work
I tried 16GB and 64GB SD card media, and they can be mounted without any problems.
There may be a problem with the SD card media.
SD card media with large current consumption may not be able to be mounted.
The current consumption of SD card media is a very important factor, but unfortunately it is not listed in the product datasheet.
You may be able to mount it by setting format_if_mount_failed to true.
I (345) main_task: Started on CPU0
I (355) main_task: Calling app_main()
I (355) example: Initializing SD card
I (355) example: Using SPI peripheral
I (355) example: Mounting filesystem
I (365) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (415) sdspi_transaction: cmd=5, R1 response: command not supported
I (635) example: Filesystem mounted
Type: SDHC/SDXC
Speed: 20.00 MHz (limit: 20.00 MHz)
CSD: ver=2, sector_size=512, capacity=31116288 read_bl_len=9
SSR: bus_width=1
I (575) example: Filesystem mounted
Type: SDHC/SDXC
SSR: bus_width=1
Type: SDHC/SDXC
CSD: ver=2, sector_size=512, capacity=121110528 read_bl_len=9
SSR: bus_width=1
#ifdef CONFIG_EXAMPLE_FORMAT_IF_MOUNT_FAILED
.format_if_mount_failed = true,
#else
.format_if_mount_failed = false,
#endif // EXAMPLE_FORMAT_IF_MOUNT_FAILED
Perfect, so you managed to mount your SDHC card with the sdspi standard example
using the SPI mode ?
Without any change in the code ?
Could you please confirm ? I will try with another card or check if the option format_if_mount_fail is set to false or true.
Best regards,
Best regards,
- Contact:
SD cards have different names depending on their capacity.
An SDHC card is an SD card with a capacity of 4GB to 32GB.
All 16GB media are SDHC.
https://www.coolblue.nl/en/advice/compa ... cards.html
Thank you for your answer. Here is what I get with the SDHC SD Card :
I (311) main_task: Started on CPU0
I (321) main_task: Calling app_main()
I (321) example: Initializing SD card
I (321) example: Using SPI peripheral
I (331) example: Mounting filesystem
I (331) gpio: GPIO[48]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (341) sdspi_transaction: cmd=52, R1 response: command not supported
E (391) sdmmc_sd: sdmmc_init_spi_crc: sdmmc_send_cmd_crc_on_off returned 0x106
E (391) vfs_fat_sdmmc: sdmmc_card_init failed (0x106).
I (391) gpio: GPIO[48]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
E (401) example: Failed to initialize the card (ESP_ERR_NOT_SUPPORTED). Make sure SD card lines have pull-up resistors in place.
I (411) main_task: Returned from app_main()
And here is what I get with the 2Gb SD Card :
I (381) sdspi_transaction: cmd=5, R1 response: command not supported
I (571) example: Filesystem mounted
Type: SDSC
CSD: ver=1, sector_size=512, capacity=3887104 read_bl_len=10
SSR: bus_width=1
And in attachment a photo of the two SD Cards...
Do you have any idea please ? I use the sdspi example without changing anything except the format_if_mount_fail to true.
(So use of Standard SPI mode, 4 pins).
Best regards,
Thomas
Type: SDSC
SSR: bus_width=1
Best regards,
Thomas
- 20241018_073800.jpg (1.49 MiB) Viewed 1359 times
Now, I have tried to connect my micro SDcard in quad spi mode (Using the sdspi example)
but I don't understand how to connect it...
I think in quad Spi mode, my card should have the following signals :
-CLK
-DATA0
-DATA1
-DATA2
-DATA3
-CS
Could you confirm ?
I have defined these pins in the firmware, but on the schematic of my micro SD adapter board,
I have connected :
- CLK signal on the CLK pin.
- Data 0 on the DATA 0 pin.
- Data 1 on the DATA 1 pin.
- Data 2 on the DATA 2 pin.
- Data 3 on the DATA 3 pin.
But where to connect the chip select signal ???
In attachment the schematic of my microSD adapter board.
Do you have any idea where to connect the CS signal ?
-Data
-CLK
-DATA0
-DATA1
-DATA2
-DATA3
-CS
Could you confirm ?
I have connected :
-Data
- adapter.jpg (111.19 KiB) Viewed 1318 times
- Contact:
Please use another SD card media from a reliable brand.
We can't find any other solution.
You can try limiting the SPI clock speed to some low value, like 1MHz, and see if things improve.
Good morning,
I have tried with a 1MHz frequency and things are the same.
I get exactly the same message and the card is not mounted.
So I will follow your recommandation and try with a card from another brand.
Thank you for your help,
best regards,
Thomas TRUILHE
best regards,
Thomas TRUILHE
Using the second example sdmmc, it seams that I can mount the 2Go and the 16Go card.
It is perfect thank you.
Users browsing this forum: No registered users and 165 guests
