ADC input minimum current
Pibbotley
Postby Pibbotley » Sun Feb 18, 2018 7:35 pm
To use ADC attenuation I need to buffer the pins with voltage dividers. To minimise battery power and use highest resistances what is the minimum input current for an ESP32 analog input pin?
ESP_Angus
Re: ADC input minimum current
Postby ESP_Angus » Mon Feb 19, 2018 6:22 am
ADC input current will be neglible. However, to get the most accurate results from a high impedance source (like a high value voltage divider) you can add a small buffer capacitor (approx 100nF) between the ADC pin and ground.
Pibbotley
Postby Pibbotley » Mon Feb 19, 2018 9:28 am
Excellent, thanks
mura_lb
Postby mura_lb » Fri Oct 11, 2024 8:50 am
I have a similar problem, but not for ADC.
I need to detect the generation of very small current, through the transistor and optocoupler to form a simple detection circuit, output about 2uA logic level. Can ESP32 be confirmed with such a low current?
Postby ESP_Sprite » Sat Oct 12, 2024 2:53 am
Datasheet says input leakage is 50nA max, which is an order of magnitude smaller than the 2uA you have, so it should work.
Users browsing this forum: No registered users and 56 guests
