ESP32-2432S028R (cyd) + reed switch
bonbock
Postby bonbock » Fri Sep 27, 2024 6:28 am
Hi all,
I'm knew here and kinda new on ESP IoT stuff. I built a pipeline with an esp8266 wired to a reed switch that send an http request to the esp32 cyd in case the door opens.
Now I'm wondering, is it possible to directly connect the esp32 cyd to a reed switch?
Thanks a lot for any help ♥️
MicroController
Re: ESP32-2432S028R (cyd) + reed switch
Postby MicroController » Fri Sep 27, 2024 12:05 pm
Should be possible. There seem to be a few GPIO pins available: https://randomnerdtutorials.com/esp32-c ... lable-pins
bonbock
Postby bonbock » Sun Sep 29, 2024 7:30 am
Thanks a lot. Yesterday I got my ESP32 cyd and tested on CN1 using GPIO22 and GND. Working fine.
Is it ok to use just ground and a pin with a reed switch or I will have problems?
Thanks again
MicroController
Postby MicroController » Mon Sep 30, 2024 8:34 am
No problems there. Set the pin as input, enable the internal pull up resistor, and you're good.
bonbock
Postby bonbock » Wed Oct 02, 2024 1:02 pm
Perfect, thanks a lot
Users browsing this forum: No registered users and 67 guests
