The signal lines RWA_ALARM, NORMAL_BETRIEB are pulled up (at first internal pull up it did not worked and after that in the pcb I have externally pulled up as well) but the voltage level on those lines are around 1-1.5 volts.
If anyone knows the reason/solution please let me know. (if there are any mistakes which I did please let me know)
Thanks in advance.
Pull up does not work.
- schematic.png (245.03 KiB) Viewed 1087 times
Re: Pull up does not work.
Hello @Saichander
have a look here: https://docs.espressif.com/projects/esp ... /gpio.html. GPIO34 to GPIO39 don't have internal pull-up (or pull-down) capabilities.
Excerpt from that page: GPI: GPIO34-39 can only be set as input mode and do not have software-enabled pullup or pulldown functions.
As for the external pull-ups - maybe they are too weak?
Felix
Felix
How is the schematic bit that derives those two signals supposed to work? If any, I don't see a way for the MOSFETs to stop conducting: as soon as they start conducting (and the gate capacitance is charged) there's no way for the gate capacitance to discharge again.
Users browsing this forum: No registered users and 73 guests
