Logic analyzer on ESP32 for self-diagnostics
Re: Logic analyzer on ESP32 for self-diagnostics
Thanks a lot! Static 40 MHz sample rate seems to work fine for my use case. I would also like to send packages at 40 MHz as a kind of automation. I will try to figure out how.
I had to do the following changes for slave mode (using external clock) on ESP32:
It seems to capture sd interface signals stable with 20 MHz clock.
gpio_matrix_in(SD_CLOCK_PIN, I2S0I_WS_IN_IDX, false);
I2SX.conf.rx_slave_mod = 1;
// logic_analyzer_ll_set_clock(sample_rate);
