Can ESP32 alone can generate 40MHz square wave using LEDC library?
zennya
Postby zennya » Sat Sep 14, 2024 11:00 am
I happen to surf around this forum and found interesting, but old (currently uncompilable codes under ESP-IDF 5) codes.
Fyi, https://esp32.com/viewtopic.php?t=1037#p14480 provides an example to generate 20MHz square wave at 50% duty on GPIO18 using LEDC library alone.
Being new to the esp32 and C, I tried to make a few changes and made an .ino file from the code:
include "driver/ledc.h"
void setup() {
  ledc_timer_config_t ledc_timer = {
    .speed_mode = LEDC_HIGH_SPEED_MODE,
    .timer_num  = LEDC_TIMER_0,
    .bit_num    = 2,
    .freq_hz    = 20000000
ledc_channel_config_t ledc_channel = {
    .channel    = LEDC_CHANNEL_0,
    .gpio_num   = 18,
    .timer_sel  = LEDC_TIMER_0,
    .duty       = 2
void loop() {
    ledc_timer_config(&ledc_timer);
    ledc_channel_config(&ledc_channel);
    while (1) {
But it refuses to compile in esp32 dev board with the error that reads:
/path/to/esp32-ledc.ino: In function 'void setup()':
esp32-ledc:10:1: error: designator order for field 'ledc_timer_config_t::<unnamed union>::bit_num' does not match declaration order in 'ledc_timer_config_t'
esp32-ledc:18:1: error: designator order for field 'ledc_channel_config_t::gpio_num' does not match declaration order in 'ledc_channel_config_t'
/path/to/esp32-ledc.ino: In function 'void loop()':
esp32-ledc:24:24: error: 'ledc_timer' was not declared in this scope
/path/to/esp32-ledc.ino:24:24: note: suggested alternative: 'ledc_timer_t'
                        ledc_timer_t
esp32-ledc:25:26: error: 'ledc_channel' was not declared in this scope
/path/to/esp32-ledc.ino:25:26: note: suggested alternative: 'ledc_channel_t'
                          ledc_channel_t
exit status 1
Just wondering is 40Mhz with mere esp32 possible? Is ther any way to convert the C code above to .ino in v5+ of ESP-IDF?
Thanks in advance, and have a nice weekend.
MicroController
Re: Can ESP32 alone can generate 40MHz square wave using LEDC library?
Postby MicroController » Sun Sep 15, 2024 11:40 am
Try it like this:
ledc_timer_config_t ledc_timer { };
    ledc_timer.speed_mode = LEDC_HIGH_SPEED_MODE;
    ledc_timer.timer_num  = LEDC_TIMER_0;
    ledc_timer.bit_num    = 2;
    ledc_timer.freq_hz    = 20000000;
And yes, the LEDC should be able to generate a 40MHz square wave, cf. https://docs.espressif.com/projects/esp ... esolutions
zennya
Re: Can ESP32 alone generate 40MHz square wave using LEDC library?
Postby zennya » Mon Sep 16, 2024 6:23 am
Try it like this:
@MicroController:
Thanks for your input. Yet being new, I could not figure out how to get it built. I am sure I must be somewhere wrong. Any input appreciated.
The stdout with error-logs from esp-idf is posted at https://termbin.com/p4qi
The debug output from arduino-ide is in https://termbin.com/2xqy
To avoid long path of the project directory, I just replaced them with
/path/to/project
Meanwhile, I have tried with the code in https://esp32.com/viewtopic.php?t=4560#p57367 without success. I am trying to learn slowly by walking in the guidance of stalwarts and veterans here. So bear with me.
Thanking you in anticipation.
MicroController
Postby MicroController » Mon Sep 16, 2024 7:20 am
sketch_sep15a:2:3: error: 'ledc_timer_config_t' was not declared in this scope
indicates that your code may be lacking an
#include "driver/ledc.h"
Not sure about Arduino vs. IDF (versions, dependencies,...) though, so it may be easier to use Arduino only:
https://espressif-docs.readthedocs-host ... /ledc.html
zennya
Postby zennya » Mon Sep 16, 2024 9:24 am
@MicroController: Thanks for prompt response. I shall follow suit to your advice to use Arduino only in that case.
However when I appended the header file
, still it does not compile with errors that reads:
/path/to/project/sketch_sep15a/sketch_sep15a.ino: In function 'void setup()':
sketch_sep15a:7:29: error: invalid conversion from 'int' to 'ledc_timer_bit_t' [-fpermissive]
/path/to/project/sketch_sep15a/sketch_sep15a.ino: At global scope:
sketch_sep15a:18:1: error: designator order for field 'ledc_channel_config_t::gpio_num' does not match declaration order in 'ledc_channel_config_t'
/path/to/project/sketch_sep15a/sketch_sep15a.ino: In function 'void loop()':
sketch_sep15a:22:24: error: 'ledc_timer' was not declared in this scope
/path/to/project/sketch_sep15a/sketch_sep15a.ino:22:24: note: suggested alternative: 'ledc_timer_t'
                        ledc_timer_t
exit status 1
Fyi, the sketch that produced above error during compilation looks like the following:
void setup() {
    ledc_timer.freq_hz    = 10000000;
    .gpio_num   = 18,
    .duty       = 2
void loop() {
    while (1) {
MicroController
Postby MicroController » Mon Sep 16, 2024 9:44 am
Instead of 2, use LEDC_TIMER_2_BIT.
Same issue as with the initialization of ledc_timer before. Try initializing each field individually.
Also, now setup() does nothing, and loop() cannot use &ledc_timer because ledc_timer is only visible in setup().
Users browsing this forum: No registered users and 73 guests
