Not able to build in Eclipse
stefaanv
Postby stefaanv » Wed Sep 06, 2017 7:49 am
I'm trying to set up the IDF development environment according to instructions on http://esp-idf.readthedocs.io/en/latest/get-started/
IDF_PATH environment variable is set up and compiling from the mingw32 shell works fine.
However, after a lot of effort I still fail to set up Eclipse to compile code directly from within Eclipse. because of this, my code is all lit up with errors which makes Eclipse prettyu much useless. According to this forum these errors should disappear after the first build from Eclipse.
I get this error message :
09:43:28 **** Incremental Build of configuration Default for project disp_templogger ****
make all
Cannot run program "make": Launching failed
Error: Program "make" not found in PATH
PATH=[...;C:\Program Files\msys32\mingw32\bin;C:\Users\svd3kk3\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Eclipse;C:\Program Files\msys32\opt\xtensa-esp32-elf\xtensa-esp32-elf\bin;C:\Users\svd3kk3\esp32\esp-idf]
09:43:28 Build Finished (took 109ms)
As you can see, the xtensa bin files are included in the Eclipse path, as well as the esp-idf path.
Can anyone help ?
Stefaan
Users browsing this forum: Google [Bot], Jorgie and 96 guests
