Hi, my first post.
I have a ESP32-H2-MINI hooked up up on USB port.
I can program in the HWCDC_Events example out the 'ESP32' folder, that works fine but if I try any of the other USB examples like USBVendor out of the 'USB' folder, nothing happens. Perhaps there is something in the examples configuration that I need to change, or maybe they are not for this device?
I am looking for more USB examples that will work with ESP32-H2. I would specifically like to set the module up as a custom HID device for one project and as a mouse for another project.
Any pointers appreciated, thank you.
USB examples for ESP32-H2-MINI
Re: USB examples for ESP32-H2-MINI
The -H2 does not have the USB-OTG controller you'd need for those examples; it only has a fixed-function USB-serial-JTAG controller.
Ok thanks, makes sense now.
Does that mean there are no modules that have a fully fledged that USB small enough go into a USB dongle? WROOM is too wide.
The other chips also have -mini variants of their modules, e.g. the esp-s3-mini-1. Possibly those are small enough.
The 8684/8685 modules have some small and different form factors that may work for you, although this means that they have lower production volumes and availability.
https://www.espressif.com/en/products/modules
https://products.espressif.com/#/product-selector
Thanks all,
What I really need is a mini format but with both Bluetooth Classic and either USB CDC or USB.
Looks like I'm out of luck.
Those also don't have USB OTG.lbernstone wrote: ↑Tue Aug 06, 2024 5:28 pmThe 8684/8685 modules have some small and different form factors that may work for you, although this means that they have lower production volumes and availability.
Is that S3 module still too large?thepurplepig wrote:Looks like I'm out of luck.
Does the S3 do bluetooth classic as well? I thought not but if it does that ticks all boxes.ESP_Sprite wrote: ↑Wed Aug 07, 2024 3:39 amIs that S3 module still too large?thepurplepig wrote:Looks like I'm out of luck.
*just checked seems not. So there are no BTC capable modules with USB OTG and vice versa.
However I could make do with USB HWCDC and not fully fledged OTG, but there is no USB CDC in the part selector.
If I select 'USB OTG' in the selector, are parts with HWCDC also listed?
If not, are there any parts with USHWCDC and Bluetooth Classic?
Nope. Only chip that does BT Classic is the 'original' ESP32, and that does not have USB of any sort.
Users browsing this forum: Masoud123456 and 96 guests
