Copy the image from partition to partition
aygh4266
Postby aygh4266 » Wed May 29, 2024 11:35 am
Hello Everyone,
i am trying to copy a binary image located on a data fat partition to an app partition to set the boot from the app partition.
My Idea is to allocate a buffer and read and write the image in loop. Unfortunately is the copied image invalid and i keep getting these log messages:
E (3024) esp_image: image at 0x110000 has invalid magic byte (nothing flashed here?)
E (3034) example_main: Failed to set boot partition to OTA_0: ESP_ERR_OTA_VALIDATE_FAILED
Here is the code:
  1.  void copy_image_to_ota0() {
  2.     const esp_partition_t *storage_partition = esp_partition_find_first(ESP_PARTITION_TYPE_DATA, ESP_PARTITION_SUBTYPE_DATA_FAT, "storage");
  3.     if (!storage_partition) {
  4.         ESP_LOGE(TAG, "Storage partition not found");
  5.         return;
  6.     }
  7.
  8.     const esp_partition_t *ota_0_partition = esp_partition_find_first(ESP_PARTITION_TYPE_APP, ESP_PARTITION_SUBTYPE_APP_OTA_0, NULL);
  9.     if (!ota_0_partition) {
  10.         ESP_LOGE(TAG, "OTA_0 partition not found");
  11.         return;
  12.     }
  13.
  14.     if (storage_partition->size > ota_0_partition->size) {
  15.         ESP_LOGE(TAG, "Storage partition is larger than OTA_0 partition");
  16.         return;
  17.     }
  18.
  19.     ESP_LOGI(TAG, "Copying image from storage to OTA_0 partition");
  20.     const int BUFFER_SIZE = 4096;
  21.     void *buffer = malloc(BUFFER_SIZE);
  22.     if (!buffer) {
  23.         ESP_LOGE(TAG, "Failed to allocate memory for buffer");
  24.         return;
  25.     }
  26.
  27.     size_t offset = 0;
  28.     esp_err_t err;
  29.     while (offset < storage_partition->size) {
  30.         size_t bytes_to_copy = MIN(BUFFER_SIZE, storage_partition->size - offset);
  31.
  32.         err = esp_partition_read(storage_partition, offset, buffer, bytes_to_copy);
  33.         if (err != ESP_OK) {
  34.             ESP_LOGE(TAG, "Failed to read from storage partition at offset 0x%08x: %s", offset, esp_err_to_name(err));
  35.             free(buffer);
  36.             return;
  37.         }
  38.
  39.         err = esp_partition_write(ota_0_partition, offset, buffer, bytes_to_copy);
  40.         if (err != ESP_OK) {
  41.             ESP_LOGE(TAG, "Failed to write to OTA_0 partition at offset 0x%08x: %s", offset, esp_err_to_name(err));
  42.             free(buffer);
  43.             return;
  44.         }
  45.
  46.         ESP_LOGD(TAG, "Copied %d bytes from offset 0x%08x", bytes_to_copy, offset);
  47.         offset += bytes_to_copy;
  48.     }
  49.
  50.     ESP_LOGI(TAG, "Image copied successfully to OTA_0 partition");
  51.     free(buffer);
  52. }
liaifat85
Re: Copy the image from partition to partition
Postby liaifat85 » Wed May 29, 2024 3:19 pm
You can try this edited version of your code:
#include "esp_partition.h"
#include "esp_log.h"
#include "esp_ota_ops.h"
#include <stdlib.h>
#define TAG "example_main"
        return;
        return;
        return;
    if (!buffer) {
        return;
    size_t offset = 0
MicroController
Postby MicroController » Wed May 29, 2024 8:32 pm
Is there a FAT filesystem on this partition?
How do you get the image into this storage partition?
aygh4266
Postby aygh4266 » Thu Jun 20, 2024 8:58 am
Yes, there is a FAT Parition in the partition table.csv
By Configuring the esp32s3 to act like Mass Storage device. So I can send the binary image direct from my PC or smartphone using USB OTG.
MicroController
Postby MicroController » Thu Jun 20, 2024 11:17 am
You can't copy a FAT filesystem into an OTA partition and expect the FAT to be a valid firmware image.
ok-home
Contact:
Postby ok-home » Thu Jun 20, 2024 1:58 pm
why can't the OTA API
esp_ota_begin/esp_ota_write/esp_ota_end
be used with fread ?
Users browsing this forum: Baidu [Spider] and 101 guests
