Dear community,
I am currently using the ESP-32 as a socket server, sending around 500 bytes every 500ms for each client that connects on the network.
Sometimes I receive the following warning repeatdly:
W (223029) wifi:[ADDBA]rx delba, code:37, delete tid:0
However, my network continues to work fine.
Does anyone know what this waning means?
Thank you,
Rodrigo
Help in Decoding Wifi W (223029) wifi:[ADDBA]rx delba, code:37, delete tid:0
Re: Help in Decoding Wifi W (223029) wifi:[ADDBA]rx delba, code:37, delete tid:0
I got the same messages..
My device is running as an AP, but I sometime cannot connect to it.
Even the device shows "esp_netif_lwip: DHCP server assigned IP to a client, IP is: 192.168.10.2", I still cannot reach the device by ping.
Anything wrong in below log?
I (46217) wifi:[ADDBA]RX DELBA, reason:37, delete tid:0, initiator:1(originator)
I (46217) wifi:<ba-del>idx:2, tid:0
I (51209) wifi:[ADDBA]RX DELBA, reason:37, delete tid:0, initiator:1(originator)
I (51209) wifi:<ba-del>idx:2, tid:0
I (51210) wifi:[ADDBA]RX DELBA, reason:37, delete tid:0, initiator:1(originator)
I (55340) wifi:station: 20:1e:88:5e:2b:3f leave, AID = 1, reason = 4, bss_flags is 167011, bss:0x3c1283a4
I (55341) wifi:new:<6,0>, old:<6,0>, ap:<6,0>, sta:<0,0>, prof:6, snd_ch_cfg:0x0
I (103282) wifi:removing station <20:1e:88:5e:2b:3f> after unsuccessful auth/assoc, AID = 0
W (103283) wifi:rm mis
I (103283) wifi:new:<6,0>, old:<6,0>, ap:<6,0>, sta:<0,0>, prof:6, snd_ch_cfg:0x0
I (138092) wifi:removing station <20:1e:88:5e:2b:3f> after unsuccessful auth/assoc, AID = 0
W (138093) wifi:rm mis
I (138093) wifi:new:<6,0>, old:<6,0>, ap:<6,0>, sta:<0,0>, prof:6, snd_ch_cfg:0x0
I (171455) wifi:new:<6,0>, old:<6,0>, ap:<6,0>, sta:<0,0>, prof:6, snd_ch_cfg:0x0
I (171455) wifi:station: 20:1e:88:5e:2b:3f join, AID=1, bgn, 20
I (171609) esp_netif_lwip: DHCP server assigned IP to a client, IP is: 192.168.10.2
I (174603) wifi:[ADDBA]RX DELBA, reason:37, delete tid:0, initiator:1(originator)
I (174604) wifi:<ba-del>idx:2, tid:0
I (177898) wifi:[ADDBA]RX DELBA, reason:37, delete tid:0, initiator:1(originator)
I (177898) wifi:<ba-del>idx:2, tid:0
I (177899) wifi:[ADDBA]RX DELBA, reason:37, delete tid:0, initiator:1(originator)
I (180711) telnet_server: Socket accepted, connected from 192.168.10.2:48022
I (181160) wifi:[ADDBA]RX DELBA, reason:37, delete tid:0, initiator:1(originator)
I (181161) wifi:<ba-del>idx:2, tid:0
I (181161) wifi:[ADDBA]RX DELBA, reason:37, delete tid:0, initiator:1(originator)
I (185156) wifi:<ba-add>idx:2 (ifx:1, 20:1e:88:5e:2b:3f), tid:0, ssn:137, winSize:64
I (221627) wifi:station: 20:1e:88:5e:2b:3f leave, AID = 1, reason = 3, bss_flags is 167011, bss:0x3c1283a4
I (221628) wifi:new:<6,0>, old:<6,0>, ap:<6,0>, sta:<0,0>, prof:6, snd_ch_cfg:0x0
I (221634) wifi:<ba-del>idx:2, tid:0
This is the A-MPDU related feature introduced into Wi-Fi since Wi-Fi4.
Means in the Rx direction, Block Ack Agreement is deleted because of reason(37). Look up the IEEE802.11 spec, you can find that 37 means "Requesting STA is no longer using the stream or session". TID 0 is the default Access Category, and mapped into Best Effort, from ToS field of your packet.
Users browsing this forum: Bing [Bot] and 73 guests
