BOX 3 w/ Home Assistant Firmware 5.5 - No Audio
Cobalty2004
Postby Cobalty2004 » Fri Jun 14, 2024 11:27 am
I recently setup a box 3 to use as a voice assistant device for HA.
I have no audio on the device and cannot setup as a smart speaker.
Looks like this is an issue with the latest firmware.
See below for others that are having the same issue.
https://community.home-assistant.io/t/e ... /729795/23
mgsecord62
Re: BOX 3 w/ Home Assistant Firmware 5.5 - No Audio
Postby mgsecord62 » Sat Jun 15, 2024 5:41 pm
I have been using the following for one of my ESP32-S3-Box-3. It works great and you can adjust the level of the volume. You will probably want to leave the volume at max because of the puny speaker in the ESP32-S3-Box-3. It is very easy to install with the WEB installer. https://github.com/BigBobbas/ESP32-S3-B ... om-ESPHome
Cobalty2004
Postby Cobalty2004 » Sun Jun 16, 2024 11:11 pm
Thanks! When I get back from my trip I’ll try this out.
Users browsing this forum: No registered users and 7 guests
