hi
I am using esp32 dev kit.I am unable to do ble pairing with SimpleBLE example provided in arduino library. when i am searching for bluetooth devices then the name of device is visible but i unable to pair it.please guide me for the same.also provide me the email id so that i can directly communicate regarding all issue
BLE pairing
Re: BLE pairing
Howdy there,
I think you are describing the code/library found here:
https://github.com/nkolban/esp32-snippets
If so, please don't hesitate to create a problem report as an issue on Github here:
https://github.com/nkolban/esp32-snippets/issues
We try and examine/respond as quickly as possible.
As is always the case in problem reporting, please try and be as verbose as possible. If you have sample code or logs, post those as pastebins and attach to the reports as links.
Re: BLE pairing
Dear sir
I am working on a project and for that i need to work with BLE section as well so can you provide us some deadline upto which you will be able to provide stable BLE API.
Also i want to use internal RTC of ESP WROOM 32 module for the updation and setting up time without server, i couldn't find such examples regarding RTC.
If it is possible please provide the example or functions for setting up and updating time and supply pin for RTC in ESP-WROOM-32 module.
Also let me know is it possible to activate STA and AP MODE at the same time?
SENDIND YOU LOG REAGARDING BLE IN FOLLOWING ATTACHMENT
Re: BLE pairing
BLE LOG
- Screenshot_2017-08-30-12-59-21-128_uk.co.alt236.btlescan.png (64.77 KiB) Viewed 12526 times
- Screenshot_2017-08-30-12-59-12-607_uk.co.alt236.btlescan.png (151.72 KiB) Viewed 12526 times
- Screenshot_2017-08-30-12-59-07-471_uk.co.alt236.btlescan.png (158.58 KiB) Viewed 12526 times
Re: BLE pairing
BLE LOG FILES
- Screenshot_2017-08-30-13-00-24-685_uk.co.alt236.btlescan.png (65.47 KiB) Viewed 12526 times
- Screenshot_2017-08-30-12-58-29-664_uk.co.alt236.btlescan.png (45.91 KiB) Viewed 12526 times
- Capture.JPG (54.71 KiB) Viewed 12526 times
Users browsing this forum: No registered users and 66 guests
