Reading API Chunked Response in C
savethebrain
Postby savethebrain » Wed Jun 05, 2024 2:36 pm
I'm building a Firebase API in C for esp32-c3
Currently I'm able to construct the url and perform a request but for some reason I can't read any data from the response and response len is always 0
here's the code and the output
void firebase_login_user(Firebase* self, char* email, char* password) {
    char* url = malloc(strlen(self->api_key) + 78);
    if (url == NULL) {
        ESP_LOGE(TAG, "Error allocating memory for URL");
        return;
    strcpy(url, "https://www.googleapis.com/identitytoolkit/v3/relyingparty/verifyPassword?key=");
    char *full_url = strjoin(url, self->api_key);
    free(url); // Free the initial allocation
    if (!full_url) {
        ESP_LOGE(TAG, "Error joining URL");
        return;
    cJSON *root = cJSON_CreateObject();
    cJSON_AddStringToObject(root, "email", email);
    cJSON_AddStringToObject(root, "password", password);
    cJSON_AddTrueToObject(root, "returnSecureToken");
    char *data = cJSON_Print(root);
    ESP_LOGI(TAG, "URL: %s", full_url);
    ESP_LOGI(TAG, "JSON: %s", data);
        .url = full_url,
        .method = HTTP_METHOD_POST,
        .transport_type = HTTP_TRANSPORT_OVER_SSL,
    esp_http_client_handle_t client = esp_http_client_init(&config);
    if (client == NULL) {
        ESP_LOGE(TAG, "Failed to initialize HTTP client");
        free(full_url);
        cJSON_Delete(root);
        free(data);
        return;
    esp_http_client_set_header(client, "Content-Type", "application/json; charset=UTF-8");
    esp_http_client_set_post_field(client, data, strlen(data));
    esp_err_t err = esp_http_client_perform(client);
    if (err == ESP_OK) {
        ESP_LOGI(TAG, "HTTP POST Status = %d, %s", err, esp_err_to_name(err));
        int http_status = esp_http_client_get_status_code(client);
        ESP_LOGI(TAG, "HTTP Status Code = %d", http_status);
        int content_length = esp_http_client_get_content_length(client);
        ESP_LOGI(TAG, "Content Length = %d", content_length);
        if (http_status == 200) {
            if (content_length == -1) {
                // Handle chunked transfer encoding
                ESP_LOGI(TAG, "Chunked response");
                char *buffer = malloc(512);
                if (buffer == NULL) {
                    ESP_LOGE(TAG, "Error allocating memory for buffer");
                } else {
                    int total_data_read = 0;
                    int data_read;
                    do {
                        data_read = esp_http_client_read(client, buffer, 512);
                        if (data_read > 0) {
                            buffer[data_read] = '\0'; // Null-terminate the response
                            ESP_LOGI(TAG, "Chunk: %s", buffer);
                            total_data_read += data_read;
                        } else if (data_read < 0) {
                            ESP_LOGE(TAG, "Error reading data");
                    } while (data_read > 0);
                    ESP_LOGI(TAG, "Total data read: %d", total_data_read);
                    free(buffer);
            } else {
                // Handle non-chunked response
                char *buffer = malloc(content_length + 1);
                } else {
                    int total_data_read = esp_http_client_read(client, buffer, content_length);
                    if (total_data_read >= 0) {
                        buffer[total_data_read] = '\0'; // Null-terminate the response
                        ESP_LOGI(TAG, "Response: %s", buffer);
                    } else {
                    free(buffer);
        } else {
            ESP_LOGE(TAG, "Unexpected HTTP status code: %d", http_status);
    } else {
        ESP_LOGE(TAG, "Error performing HTTP request: %s", esp_err_to_name(err));
    cJSON_Delete(root);
    free(data);
    free(full_url);
Output
I (12824) netlog: HTTP POST Status = 0, ESP_OK
I (12824) netlog: HTTP Status Code = 200
I (12824) netlog: Content Length = -1
I (12824) netlog: Chunked response
I (12834) netlog: Total data read: 0
I (12834) main_task: Returned from app_main()
Any idea what am I doing wrong?
This is the equivalent of what I'm trying to do in Python, which works perfectly
    def login_user(self, email, password):
        request_link = f"https://www.googleapis.com/identitytoolkit/v3/relyingparty/verifyPassword?key={self.api_key}"
        headers = {"content-type": "application/json; charset=UTF-8"}
        data = json.dumps({"email": email, "password": password, "returnSecureToken": True})
        request_data = self.requests.post(request_link, headers=headers, data=data)
        self.error_http(request_data)
        self.currentUser = request_data.json()
        self.token = self.currentUser["idToken"]
        return request_data.json()
Thanks.
parthbhat13
Re: Reading API Chunked Response in C
Postby parthbhat13 » Tue Jul 02, 2024 9:22 am
i wonder if the problem you are facing is actually solved?
there is even another thread where the instructions to use the
is actually very much unclear, they do mention to use the event Handel to read the data.
here is the link for the other thread i could find stating the issue. https://esp32.com/viewtopic.php?f=13&t= ... 10#p134310
and the only example which is given is the following, where
is not implemented.
https://github.com/espressif/esp-idf/bl ... _example.c
Users browsing this forum: No registered users and 72 guests
